How can I resolve the problem........cpu turn on &off by it self.
    Top Expert:
  • Computers & ... Master
  • 26,659 Answers
Clean the fan and radiator.
Posted on Nov 30, 2014
HP slimline pavilion s3620f pc
Try monitor self test. If passed, problem is with computer tower.
This issue can easily be resolved at http://sureconsulting.in/
Sep 08, 2012 | HP Computers & Internet
What does the fan look like for HP m7680n i need to replace it. at boot msg, fan failed press F2 to continue etc.
  • With the power off open the case. Generally it is the left panel that will slide off after you remove the screws in the back.
  • You will see the fan setting on top of the CPU heat sink.
  • Turn on the computer. That fan should run.
  • If not, turn off the computer, remove the fan and take it to a mom & pop computer store and ask for a replacement. Shouldn't be very expensive.
  • If you don't feel comfortable do what I suggest, take the tower to a mom & pop computer store and they can do it. There might be a minimal charge in addition to the fan.
I would not run the system very long (minutes) until the fan problem is resolved as you can over heat the CPU and ruin it.
I do this for fun & 4 thumbs not for $$$$
Jim
Oct 05, 2011 | HP Computers & Internet
My CD Rom drives cannot be detected by my CPU
make sure that ur cpu power is OFFfirst, check the power cable in the cpu and check of the drive led is on. second, make sure that the data cable is well captured in the the drive to detect on the computer. third, if this dosent worked well is must the problem of the drive self and i advise to get it to ur Maintenance Center
الاستماع
Jun 05, 2011 | Computers & Internet
New printer--------paper jam 8.5w x 3.5 inch paper in printer; cannot see it!!
Print a self-test report Use the following steps to print a self-test report.
  1. Load unused, plain, white paper in the tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01438890.jpg ) on the control panel.
  4. Use the right arrow (c01185072.jpg ) to highlight Print Report , and then press OK .
  5. Use the right arrow (c01185072.jpg ) to highlight Self-Test Report , and then press OK . The self-test report prints.
c01733891.gif IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue.
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Disconnect the USB cable from the rear of the product.
  2. Press the Power button (c01602202.gif ) to turn off the product.
  3. Disconnect the power cord from the rear of the product.
  4. Remove the rear access door or the two-sided printing accessory (duplexer) from the rear of the product.
Jan 10, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp z6100 turns itself off! no error code just switches off! Makes loads of beeps and sounds like a fax machine! Help
it contains m/b like desktop with cpu,ram,hdd etc check ram cpu fan & power supply refix them after cleaning ...............may b ur problem will be resolved.
Jul 30, 2010 | HP Designjet Z6100 InkJet Printer
Just turns its self off with out any warning
How mush time stays the laptop in on state? Check the airflow ports (incoming and outgoing) and clean with a small brush and a vacuum is case of dust. Try again and report the results with a post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Acer Aspire 5500 5570-2609 Laptop
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Hello I have a monitor DELL E228WFP and it turns black after a while. I have it about 1 year, and it turns black for no reason. I wan't to know how to make the flash light test on my monitor.
Okay, there is what is known as a Diagnostic Partition in all Dell computers. When you turn on your computer you need to Tap F12 when you see your BIOS load (which is the first thing you see on your screen when you turn on your computer.) You will then see several options, if you did it correctly, and the one on the very bottom usually says something along the line of "Boot to Utility Partition" and there will be an option for a screen test. Run it.
Please tell me if you need any further assistance.
Ryan Frame
Creative Energy Associates Technical Center
Nov 13, 2009 | Dell E228WFP LCD Monitor
Beep sound when swith on
good day,
a beep from your cpu system means that there is an error. and since there is a "cpu overheat" error, it could mean that your cpu cooling system (or its fan) is not working.
the shutdown is a defense mechanism of your cpu in order for your cpu not to self distract.
have the cooling system replaced as soon as possible to avoid further damage.
i hope this will help
Oct 13, 2008 | Intel D845GVSR Motherboard
No light is on but fans on
I would bet your system has been overheating - that's why it kept shutting off. Now it may have overheated and killed your CPU or mainboard. These laptops require quite a bit of disassembly to get at the CPU. You will probably have to take it to a repair shop for further work.
Oct 06, 2007 | HP Business Notebook NX9110 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
