What is an optical connection? - Audio Players & Recorders
It is a Fiber optic connection between most newer TV's and a Blue ray player or Audio equipment
Posted on Nov 30, 2014
  • 3 Answers
It's a connection that uses a fiber optic strand that usually has a small square male connection on the 'cable' and a female connection on the devices you are connecting together.
No optical connection on my tv .how do I connect sound bar.which has optical connection
Unless the soundbar has another audio connection you can't. There is no way to convert to an optical connection.
Aug 09, 2016 | Toshiba Televison & Video
How do you hook your receiver to your TV and make surround sound come out?
There are many configurations available for making these connections. They are specific to the TV and receiver.
The most common is an optical connection from the TV to an optical input available on most receivers.
If a cable box is being used I would make the connection from the cable box using the optical output directly into the optical input of the receiver bi passing the TV. If you are connected via an antenna then you would connect the optical to the TV.
The red and white RCA connectors are not surround sound and will only produce sterio.
Hope this helps?
Mar 26, 2016 | Audio Players & Recorders
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
How do I connect the TVee 10 to a Denon 988 AV Reciever
If you want to listen to your TV through the receiver, you have to connect the TV;s Optical Output to the receiver's Optical Input.
Dec 26, 2014 | Denon Audio Players & Recorders
Want to connect fiber optic audio cable
If you have something providing an optical signal, you will need something such as a receiver that will accept and decode the optical signal. If you are able to make use of the HDMI instead of the optical audio channel, this would be the easiest bet. Otherwise you are looking at needing to get a receiver if you want to have more than 10W of stereo output, or if you simply wish to convert the optical signal into something the TV can understand, any fiber optic to analog converter, such as Amazon item B003OND0N4 (Search that string on Amazon)
Mar 28, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Connect ps3 just sound to surround sound
PS3 has an "optical out" port. Use an optical coaxial cable (something like this one XO Digital Optical Cable 2m 2 Metre Premium Install Series suitable for... ) to connect this to an optical in port on your surround sound receiver/amplifier.
Go into the sound settings on the PS3 and set it to output dolby digital 5.1 from the optical connection.
Switch your surround amplifier to the appropriate source.
Feb 03, 2014 | Video Game Consoles & Games
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
My home theater doesnt have optical connection
IT WOULD BE MORE SIMPL TO CONNECT AN AMPLIFIER WITH FIBER OPTIC INPUTS
Apr 11, 2010 | Panasonic PT-52LCX65 44" HDTV
Can't plug optical cable on MDS-JE500
optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
Mar 01, 2009 | Sony MDS-JE520 Mini Disc Player
124 people viewed this question
 Grubhead
Grubhead
