Why doesn't the second stage cooling work
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
If you have a two stage cooling system, you are probably unaware of its turning the second stage on and off unless you are right there listening to it or have the proper tools with which to tell. Most of the times, it is just a higher speed that the compressor runs on with a change to stage two.
Many times, a two stage cooling stat is installed in a single stage system because that is what was on the service truck. If so, it will operate the same on first stage as a single stage will. Usually the tech gets into the setup and changes the configuration to make the stat believe it is only has one stage. Many people may think they have an option that's not there.
Just a possibility.
Posted on Dec 02, 2014
1st stage of heat blows cold air
What is the model numbers of your units?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 05, 2017 | Heating & Cooling
Something fell into the cigarette lighter and it sparked now the radio will only eject and load cd's but it doesn't do anything else after that stage i checked and replaced the radio fuse and
you need to remove what ever dropped into the outlet then replace the power outlet fuse the radio uses more than one fuse memory amp and lights
Aug 06, 2012 | Suzuki Swift Cars & Trucks
I have a Toshiba 32a33 TV, I have tried to program channels into the TV but it doesn't work. I tried to do it both manually and using the automatic channel tuner but it doesn't work. What should I...
Either the tuner or the video IF stage circuit of your TV is faulty. Tuner has no repair, can be replaced as a unit. If the fault is with video IF stage, it can be repaired. But, both the work is skilled one. You must have through knowledge in electronics, and work experience to do this work.
Jul 21, 2012 | Televison & Video
Red button doesn't show on Philips TV after digital switchover
What is the exact model number to your Philips TV?
Apr 21, 2012 | Televison & Video
I got my 500/1 amp a little wet, wasnt much water at all...i believe it my have got inside the amp... it will power up... but will not give any output... could it b a fuse .... i have 2 of these amps in...
Most modern amps are DC coupled. That means the bias (and therefore the quiescent current) for the later power stages (those stages that do the work and get warm) is set in the earlier stages.
The high gain of the earlier stages means a tiny change there can produce big changes in the way the later stages work. Those early stages are sensitive and more delicate so some damp and dust or dirt can cause far reaching damage.
Time to consult a repair shop...
Nov 13, 2017 | Jl Audio 500/1V2 Car Amp
I am trying to install a thermostat and I am not sure where to put all the wires... it is for american standard freedom 90 two stage - furnace and air conditioning
Should be like this:
Y from furnace goes to Y on thermostat (yellow)
C from furnace goes to C on thermostat (usually blue)
G from furnace goes to G on thermostat (green)
W1 (first stage heat) to w1 on thermostat(white)
w2 (second stage heat) to w2 on thermostat (black)
Doesn't sound like you have a heat pump but if you do "o" will also have to be connected which is the reversing valve.
Jun 21, 2011 | Heating & Cooling
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
What do two snow flakes on the left side of the control display mean on a Robert Shaw 9420 thermostat?
The double snowflake means that the second stage cooling is on. (One snowflake indicates first stage cooling.) This gives a greater temperature change in extremely hot conditions with than you could get with a single cooling medium and drier air in your home.
From the patent: A two stage cooling system in which the first stage's cooling affect is transferred to the second stage through direct contact with an oil-like material. The oil-like material is cooled by direct contact with water which has been evaporatively cooled. The oil-like material is then utilized to cool the air stream prior to the second stage evaporative cooling. The use of an oil-like material in the first cooling stage of evaporative cooling allows a relatively dry air stream to be produced so as to fully capitalize upon the evaporative cooling affect of the second stage cooler.
The second stage comes on if your system hasn't reached the desired temperature at the thermostat within a programmed length of time (5 minutes is a usual setting). BTW: Your system also has two stage heating.
I hope this helps.
Jul 07, 2010 | Shaw Robert RS-9420 Thermostat
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
