Question about Ryobi Garden
Hi, I have a new ryobi touch start weedeater. I have used it twice. I charged it overnight for first use. It worked fine. After 2nd use ran out of charge so I re charged it . It doesn't seem
I have tried re charging
  • 1,536 Answers
If it doesn't seem to be recharging or taking a full charge, check the charging jack to make sure no foreign object (leaf debris, etc) got into it. If it is clean, then you probably have a warranty issue with the battery or charging system.
Note: do not leave the string trimmer out in the sun or outdoors in cold weather while it is charging. The charging process only works properly at room temperature. In particular, lithium batteries are very finicky about charging conditions. Charging overheated lithium batteries can cause a fire, so they have a safety circuit to prevent charging outside the proper temperature range.
Posted on Nov 30, 2014
  • Diane riddler
    Diane riddler Nov 30, 2014
    Thanks Paul for your prompt reply! I checked the charging jack and it is clean. It has only been charged inside at room temperature. As it is new I will take it back to the store. Thanks heaps!
scrodamoon
  • 659 Answers
SOURCE: my weed eater will start but when I push on throttle it dies
well take the spark plug out take some WD40 and give it a shot inside the unit, remember to keep the unit level when hitting the throttle and allowing it to warm up for a few minutes before use also make sure where your choke lever is. also when starting I start it on the ground like most manuals state and leave it idle on the ground for a minute before picking it up and then when I pick it up I make sure that the gas tank is tilted towards the ground so there is no room for air to get into the filter causing and disturbance while the unit is warming up.
Posted on Nov 18, 2008
Healeyman
  • 1198 Answers
SOURCE: ryobi weed eater will only run if i hold the choke down
Mine won't spin up till it is good and warm. Check the end of the fuel line in the gas tank to see if it is clogged or dirty or slimey. Make sure the end has not fallen off.
Posted on Apr 30, 2009
  • 127 Answers
SOURCE: My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Posted on Aug 22, 2009
  • 135 Answers
SOURCE: i have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Posted on Oct 03, 2009
Testimonial: "i,ll try this thanks a lot "
  • 183 Answers
SOURCE: the ryobi weed eater starts but then dies when you
did you set the gap on the new spark plug this you can google or check for last plug then use clean fuel/mix
Posted on Jul 29, 2010
I have Ryobi weedeater that has a new Carbuerator,getting gas to the cyl.an has good fire to the plug an will not start need help bad
Make sure u r not getting to much fuel. With switch off pull string twice then turn switch with throttle cable helded wide open try to start.good luck.new dose not mean adjusted good luck
May 31, 2014 | Ryobi Garden
Ratio for oil and gas on a ryobio weedeater
if you are using stihl oil the ratio is 50:1
Jul 03, 2010 | Ryobi Three Trimmer Combo
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 720r weedeater. Starts, stalls, won't start.
When you rebuilt the carb did you remove and replace the welch plugs. If you did not, then that is probably where your problem is. Debris, varnish and corrosion can build up under the welch plugs and the unit will not pass fuel.
Sep 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
New Ryobi EX26 Edger started twice and won't now.
turn the high mix screw just a little to the left it will have a letter H on one screw and L on the other
Jun 23, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi gas trimmer SS26, won't start hot until primed and choked, then dies.
My solution is to stop buying lawn and garden equipment from the local home centers. I too made the same fatal mistake you folks made. I bought the SS26 model Ryobi weedeater used it about 3 or 4 times and it has turned to ****. I am so pissed off I will never buy any power landscape tools from home centers again. I even bought a Troybuilt gas powered hedger and I have to work on it for 3 hours in order to use it for 1 hour. I will start buying commercially available professional gas powered landscape equipment from now on. I learned my lesson the hard way, just like you. The gas was bad??!!??!... I have used oil mixed gasoline in a lot of my two stroke eqiupment for 12 months without additives and it always burns just fine. The last Ryobi weedeater I had was 15 years old before it gave up the ghost. Thats why I bought this new one. I never had to use fresh gas everytime I used it...What a joke....I say we little people ban toghether and pass the word along to everyone we know about how junky their equipment is and how unreliable the companies are in supporting thier product. The problem with the SS26 Weedeater is the carbureator (spelling) it is an inferior piece of junk...period. After 4 uses, it will only start up, as soon as I pull the gas trigger, it dies because it leans out. I checked the spark plug (another piece of ****) and it looks like the machine was running hot, The electrode was a whiteish color indicateing a lean burn condition, nt the chocolate brown I was hoping to see. I hope this helps everyone who reads this... Spend a couple hundred extra dollars and go buy something real. Stop playing with the kids toys. This is what I am going to do to resolve the problem. They don't care about us, why should we care about them....Down to the firey pits with them....
OVER.............
Apr 30, 2009 | Ryobi Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
My ryobi cs30 wont start
what do you do when there is no spark??????????????????
how do you fix???????????
Mar 26, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Garden Logo
67 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
