Question about Garden
I have a 601 farmaster put a new battery in still well not start.Could it be the solenoid.
Tried to jump solenoid would not do nothing.
  • 4 Answers
Use a push button or a pair of channel locks and hold across the solenoid terminals - if it turns over then it would be the solenoid. Choke it and it may start
Posted on Dec 01, 2014
  • 376 Answers
SOURCE: 14 hp dynamark tractor that won't start
Have you checked the inline fuse?. Also you could unplug the ignition switch and clean the terminals, particuarly the one with red wire in it. That the one that has constant power to it and tends to corrode over time. Hope that helps.
Posted on May 23, 2009
  • 251 Answers
SOURCE: Dead starter, I think!
it does sound as though your starter is dead , depending on the make/model of starter you might be able to get a replacement carbon brush pack which will save a lot of money , please post the starter /engine details
Posted on Oct 25, 2009
huffman49
  • 235 Answers
SOURCE: My Craftsman 15.5 HP was running fine. Then
sounds like you got a wire grounded out somewhere.check for loose wires
Posted on Apr 14, 2010
aquaman987
  • 927 Answers
SOURCE: tractor won't start replaced solenoid
You have two safety interlocks that must be "made" before the engine will start.
The brake must be engaged.
The blades must be disengaged.
There may be a neutral safety too.
All of these switches must be closed to get ignition.
Gary.
Posted on Jun 07, 2011
  • 14 Answers
SOURCE: John deere Z225 riding mower
measure with a valt meter and see what your voltage is at the battery . now measure what you have for volts at the soleoid. then check to see if you are getting 12 volts to the single peg on your soleoid, usually a whitwe wire. If your not getting voltage to this wire you probably have a safety switch problem. If you are getting voltage here check to make sure you are getting voltage at the starter motor. If your getting voltage there you may have a bad ground at the starter motor or the whole motor may need to be grounded to the frame.
Posted on Sep 12, 2011
Nothing when turn key. Bought new battery and fully charged, installed, still nothing.
The "ticking" you hear is probably the solenoid trying to "connect"
The solenoid is the round thing that is the first thing the large red cable from the battery runs to. There are more wires connected to the solenoid..the TWO big ones carry the power from the battery and then jump it to the BIG cable that goes directly to the starter. You can CAREFULLY "jump" the two big connectors ON the solenoid with a screwdriver ( CAREFUL - SPARKS WILL FLY!). If the motor turns over you have a bad solenoid. Key does not have to be on, you just want the motor to turn over. NO open fuel sources!! SPARKS WILL FLY WHEN YOU JUMP.
Try this and repost, let me know.
Mar 10, 2016 | Polaris 2006 Sportsman 500 HO EFI
Hello, I have a no crank, no start issue, has new battery, and new starter, starter will engage while jumping solenoid
Not enough information to answer. Need manufacturer, year, model, engine size, and 2WD/4WD/AWD as applicable in order to answer the question.
Jan 22, 2016 | Cars & Trucks
Why won't my 1992 CRF400RR start?
jump terminals on solenoid,if it starts,get new solenoid,or check main fuse
Mar 23, 2015 | GAS Motorcycles
1997 Nissan Pickup stick shift. It will no start can puch start it. Put a new started on thinking it was that. Also tried jumping it off, nothing worked. Any ideas what it could be. Oh when trying to crank...
I would have the battery load tested as it indicates a bad cell. If the solenoid only clicks but you can push start it then the battery is too flat or dead and if a jump starting will not work then the jumped battery is feeding into a dead short in the other battery.
Jan 09, 2014 | Nissan Pickup Cars & Trucks
My voyager wont start it seems the alarm has stuck on , when i turn key nothing new battery fitted ,led light for alarm does not flash anymore /gear/milage lights do not come on ,i have taken battery off...
This may sound a bit simple but check the starter solenoid function by running an external wire to the thin wire terminal from the positive post on the battery.
If the starter does nothing then the starter is bad.
What your describing is a typical solenoid / starter problem. Given the car is now 10 year old, it is quite possible that either the solenoid or starter has failed.
Thanks for using FixYa!
Kelly
Feb 15, 2010 | 2000 Chrysler Grand Voyager
I had a problem with my starter solenoid my truck was not starting. i have a 1996 ford ranger i bought a new one the truck started a few times and then it stopped. what is my problem.
You should have your battery tested & make sure that the terminals are cleaned & well protected wth grease once charged fully. Since you crossed/jumped the solenoid & didn't get it to start until jumping the battery (providing extra voltage), that rules out the solenoid and the ignition switch. Sometimes a battery will test full without a load but will not provide the voltage to the solenoid to actually complete the circuit, thus the clicking sound. If the battery is strong, and the starter bad, the solenoid will click solidly once, passing full voltage to the starter that will either turn,hum, or do nothing. good luck
Jan 29, 2010 | 1996 Ford Ranger SuperCab
Car wont start, acts like battery is dead. battery shows full charge. full lights, buzzers, etc. put it on charger-didnt start...cleaned cable connections-didnt start...tried to jump with truck-didnt...
Check the battery +12v power connection to the starter is in good order,
Check the ground connection between the battery negative and the engine/starter motor is robust and intact.
If no problem with above, replace the starter motor.
Oct 10, 2009 | 1993 Ford Tempo
1994 ford thunderbird no start no nothing
sounds like there is heavy resistance in your start solenoid first try cleaning the stater & battery terminals if that fails replace the start solenoid
Jun 02, 2009 | 1993 Ford Thunderbird
Biek wont start just clicking?
I drive the bike every day or two and it always starts immediately. Does this sound like a starter or solenoid or something else? Well tried to jump start the bike and it wouldn't start just the same clicking sound. Also tried to jump over the solenoid with a screwdriver and nothing happened. Then I tried to push start the bike and again nothing. I can tell the battery is weak but even push starting, I should be able to start it without a battery right? ,,,
Nov 10, 2008 | 2003 ATK 260
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
