Question about Gentex 2001 Chevy Venture - All Venture models - K5 Auto-Dimming Rear View Mirror w/Compass
I have a chevy venture 2001 that is hard to start and backfires when starting also misses on number 2 cylinder
But a used compter in it also replaced cam sensor and igniteion modg.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 111 Answers
Sounds like bad coil and or wires. you need to change all spark plugs
Posted on Nov 30, 2014
Engine keeps backfiring under load motor is an enduro xl 13.5 hp
Need Make/Model/Year/Engine Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
Several possibilities:
1. Needs a valve adjustment or a valve job. Start with adjustment.
2. Needs new plugs. Start with new plugs.
3. Shear pin under flywheel is slightly damaged throwing off the timing. Remove flywheel examine shear pin for any damage. Just go ahead and replace it; if it even looks nicked or sliced.
4. Coil, or spark plug wire, is going bad. Very hard to test a coil for weakness without test equipment that the average person doesn't have. Check the first 3 problems, first. If it still backfires, then replace coil.
5. The other thing that causes backfire is fuel mixture too lean. On a small engine this is not usually an adjustment problem. It may be the fuel system/carburetor is dirty or partially clogged. It may also be an air leak in the gaskets of the intake manifold. If nothing else solves the backfire, remove the carburetor and clean or rebuild it. This is the least likely of the options so save it for last.
If compression is good and cylinder leakage is minimal, but a cylinder is misfiring or shows up weak in a power balance test, it indicates a fuel delivery or ignition problem (fouled spark plug or bad plug wire). A power balance, or cylinder balance, test should be run on a twin cylinder engine.
If an engine is hard starting, runs rough, misses or lacks power, run a cylinder balance test to determine if both cylinders are operating to their full potential. You will need an engine tachometer, a spark tester, and an insulated screwdriver.
1. Using the spark tester, with the plugs in, start engine and verify spark is equally good on both cylinders. Remove spark tester.
2. Connect engine tachometer.
3. Run engine at top no load speed. Note rpm.
4. Ground one cylinder spark plug with screwdriver. Note rpm.
5. Ground other cylinder with screwdriver. Note rpm.
The difference in RPM between the cylinders should be less than 75 rpm. If the difference between the two cylinders is greater than 75 rpm, the cylinder with the least rpm loss is the weakest and is a potential problem.
Note: If the spark plugs are new this could be an indication of a weak coil. Of course it could also be compression (rings), or valves.
Mar 24, 2015 | Garden
Won't start
If it's backfiring through the intake, then more than likely it's a timing issue. The distributor cap has the cylinder numbers molded into it where the plug wires go... Make sure the wires are in the right spots. If that's good, then it's possible the distributor isn't lined up right.
May 10, 2013 | 2001 Chevrolet Chevrolet Blazer
2001 Chevy Venture hard to start and grey smoke.
In the older cars, before all the emission laws added so much electronic garb, black smoke meant a fuel problem and grey smoke indicated a problem with internal engine parts like piston rings. Hope this helps.
Aug 02, 2012 | 2001 Chevrolet Venture
My 2001 chevy venture won't start
Check out this link, should help you understand why that security light is causing this problem.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 06, 2012 | 2001 Chevrolet Venture
2001 chevy venture security light on wont start
It may be as simple as trying a different key but the security systems on gm vehicles have had problems with the ignition cylinders going bad and preventing the car from starting.
May 19, 2010 | 2001 Chevrolet Venture
Removed two bolts from caliper on chevy venture
Here's a great video that will show you exactly how to remove the rotors from your Chevy Venture.">
Apr 06, 2010 | 2001 Chevrolet Venture
2001 Chevy Venture will not start. Turns over and tries to start
Spray "starting fluid" (AutoZone $4) into air intake. If it "starts better" then it is fuel-related. The gas in your tank may be contaminated. Whatever floated to the top is what is left in your tank. Add a gallon of new fuel, burn what you can and use a "complete fuel system cleaner" (AutoZone $9) when you fill-up.
Oct 05, 2009 | 2001 Chevrolet Venture
Reprogram computer of 2001 chevy venture
Call gm parts dept they can print a copy for you give them vin /Please rate my response thank you very much
Jan 29, 2009 | 2001 Chevrolet Venture
Backfire loss of power
have you tried removing the idle speed motor and cleaning it with throttle body cleaner, as well as port it is removed from?
Oct 17, 2008 | 1998 Dodge Dakota
Gentex 2001 Chevy Venture - All Venture models - K5 Auto-Dimming Rear View Mirror w/Compass Logo
88 people viewed this question
Top Gentex Optics Experts
Lawrence Oravetz
Timllfixit
ka4iup
ka4iup
Are you a Gentex Optic Expert? Answer questions, earn points and help others
