Question about Craftsman Snow Blower 22 In. Dual-Stage 179CC 13 x 4 in
I have a 22" craftsman snow blower walk behind. i managed to pick up a piece of wood while snow blowing. it sheered two bolts which i replaced. there is still a clunking in every revolution that i can
This is a clean,well cared for machine. hit pice of wood. sheered two bolts one on either side that is a four piece auger with four sheer pins. the auger is not making contact with other surface. once in every revolution there is a clunk.
  • Craftsman Master
  • 2,760 Answers
Look at auger inside behind the pick up screw i bet it got bent from wood piece and is hitting side of housing
plus my son showed me a neet trick to use a timing light attached to plug wire and 12volt battery you turn the advance adj on light point light at suspected bearing or scuff point and you can see it plain as day (engine running of course ) use extreeme caution when doing this !!!!
Posted on Dec 12, 2014
2 Suggested Answers
mikeforrest2
  • 18 Answers
SOURCE: Auger in snowblower blower does not turn
Check to see if cable is still ok and not broken. Also adjusted.
Posted on Feb 11, 2013
How do i set the timing on a 33 inch craftsman walk behind mower?
There is not an actual adjustment for the timing. If the sheer key on the flywheel has sheered a bit, this will cause the timing to be off. This happens if you hit something with the blades. You would have to remove the starter housing, flywheel bolts and flywheel. remove sheered key and install new.
Jul 08, 2015 | Craftsman Garden
Jd w2121 726 snow blower walk behind
Are you putting the right bolts in? Some bolts are just soft steel and will not take pressure.
Feb 11, 2015 | Garden
Snow blower will not start
sheer pin on flywheel sheered off pull flywheel and replace sheer key
Feb 23, 2014 | Troy Garden
Where is the auger sheer bolt
Figure 9 on Page 11 of the manual (linked below) shows the location of the auger shear pins. Do NOT substitute bolts for shear pins!
http://www.searspartsdirect.com/partsdirect/user-manuals/8227/536881800-Craftsman-Parts-SNOWTHROWER,+GAS-manual?pathRender=fromManualTabPage
Feb 11, 2013 | Craftsman Sears Snow Thrower Manual Model...
Feb 10, 2013 | Craftsman Snow Blower / Snowblower Bottom...
I am replacing the engine on a Craftsman Snow Blower. What is the engine to chassis mounting bolt torque amount?
Do not have a true answer other than to say it's probably a 5/16" bolt. 40 ft lbs would be about right for that
Jan 08, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman Snow Blower 22 In. Dual-Stage 179CC 13 x 4 in Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
