Question about All-Power America Garden
My kew dynamic 4360 power washer stops and starts
Taken off the water entry pipe cleaned filter inside and refix.do you think it might be the pump?
    New Friend:
  • 47 Answers
Possibly a blocked lance jet, does the spray pattern of the jet look good, a nice fan?
Posted on Dec 08, 2014
4 Suggested Answers
  • 607 Answers
SOURCE: Alto Force Kew washer stopped working.
To remove the cover, undo the two screws holding on the equipment tray on the handle. Then turn upside down and undo the two screws on the bottom. You will need a very long handled screw driver to reach into the deep recesses. I think they may to TORX screws (working from memory and has been a while since I pulled one apart). The blue cover will now pull off. The only trouble you may have is that the bolts are ordinary black steel ones and may have rusted through
Most likely fault is that the pressure switch has failed open. A combination of dirty water leaking past the seals and rust will eventuall jam the switch. The switch assembly is the white plastic part directly bolted onto the pump. A plunger is pushed by the pump when it is up to pressure which trips a micro switch and turns the power off. You will need to replace the complete pressure switch which is about $60. If you take care the micro switch assembly can be removed and then put back onto the new switch. If you break it, then another $40.
Posted on Jan 12, 2009
  • 68 Answers
SOURCE: My Hobby88 pressure washer stopped working, now I
Could be just a faulty capacitor that helps the motor to start. You will find this next to the motor if you remove the top cover.
Posted on Apr 21, 2010
woobie dog
  • 1273 Answers
SOURCE: Water flows thru the pressure washer pump and out
Let the water run for a longer time. "Walk" the hoses, from the faucet to the pump and then to the nozzle, holding the hoses up to displace any trapped air in the lines through the pump and out the nozzle. What it sounds like is that air is reaching the pump. When it does, it cavitates, and no water can be pumped. Tighten all of your hose fittings securely. Try holding the trigger down while starting the washer. It may be easier with another person helping.
Best regards, --W/D--
Posted on Jul 08, 2011
Problem with LG WM1814CW Front Load Washer. It has stopped with water inside and it says OE. I have checked the back pipe, but with water inside, can i open filter
The OE error is telling you the water hasn't drained out in ten minutes. To fix I would first start with cleaning the filter on the pump. If that doesn't fix i would recommend replacing the pump. I would also have towels and a mop in hand because when you unscrew the filter top the water that is inside the tub will come out. You should try leaning washer back before removing filter to prevent the mess.If you have to replace the pump they run about 50 or 60 bucks. I hope this helps.
Oct 27, 2012 | LG WM1814CW Front Load Washer
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
Water pouring out of the pump on my kew powerwash
Hi, You can get this seal set for a 1502v from nilfisk alto or any alto dealer.
Dec 27, 2009 | Garden
My washing machine is not finishing a cycle and is not pumping out the water. It will start a cycle, but then it will stop half way through, and the "delay/start" button will flash red. Please help
i had same issue turned out pipe was blocked and washing machine gave up trying to get rid of water, so would stop, cleaned filter, uncloged drainig pipe and was good to go
May 12, 2009 | Hoover Nextra HNF 3157 Front Load Washer
My towels always smell sour...it doesn't matter what detergent or fabric softener I use. I have the Whirlpool Duet front loading machine and dryer.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not cleaning clothes
Try using powders for 'front loaders'
Apr 05, 2009 | Kenmore HE2 Plus Front Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
Mold smell
Aug 23, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Washer J14535 comes up with 4E error but there is no problem with the water feed all filters are clean and wastpipe is not blocked any advice?
there is problem with inbuilt water filter which is get choked,which is located inside water valve where inlet pipe attaches.remove inlet pipe from inlet valve by hand,remove filter inside the valve clean & refix it check the pressure in detergent box
Jun 01, 2008 | Samsung Washing Machines
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Garden Logo
173 people viewed this question
Top All-Power America Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an All-Power America Garden Expert? Answer questions, earn points and help others
