Question about Whirlpool Washing Machines
Whirlpool Duet Front load washer has E02 F08 error code
Cleaned the soap dispenser tray mODEL # wfw94hexw1
    Problem Solver:
  • 59 Answers
Try this website:RepairClinic.com Lots of useful information including troubleshooting and parts.
Posted on Dec 03, 2014
2 Suggested Answers
SOURCE: I have 2 error codes
well I'll just say it's the kaputnick gate valve located at the whirlpool headquarters since no-one else seems to have the same explanation for a single error code
Posted on Oct 28, 2012
Whirlpool washer f08 e02
An F08 E02 error is a dispenser motor error on many Whirlpool washers. This could be due to dried detergent clogging the dispenser. Take the dispenser out and clean it following the directions in your manual. (Add a comment with the model number if you need a link to the manual. Most Whirlpool manuals are available on their support page: http://www.whirlpool.com/manuals/ .)
If that doesn't fix the problem or is only a temporary fix, the dispenser motor/switch may be faulty or the linkage between the motor and the dispenser may be blocked from moving freely. Alternatively the wiring may have a problem with a conductor in the wiring harness. Inside the top panel of the washer is usually a guide for checking the error. (The back panel has to be removed to get to the top panel and this information.)
I hope this helps.
Feb 19, 2015 | Whirlpool Washing Machines
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
Water leaking out of soap dispenser
I have had this happen. I have taken the dispenser tray out and cleaned the area where the water and the detergent will flow into the washer at. This area had gotten some gunk build up, once I cleaned it, it has not leaked since. Now I just routinely look at this and make sure that it is clean. Hope this helps you.
Mar 06, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlepool duet front load washer error codes F01 and E02
Whirlpool Duet Washer model number WFW94HEW2
My wife put a bunch of wet towels in the washer after this we got Codes F01 E02. I freaked out.
Under the top(roof) panel of machine there is was a service technicians manual that explain how to enter Service Diagnostic mode and explained fault/error codes and their possible causes. This isnt for the faint among us. But if you can solder and work with electronics you can diagnose the problem. The technician manual tells you check this, then this and if that doesn't work/ or does work go to 'C', then go to 'D' etc. Either way I ended up diagnosing that it was my MCU (motor control Unit), you did have to use my multi-meter, for ohms and resistance, but it wasn't rocket science. Upon close observation there was a burnt connection solder point on the board. I looked up the part online and ordered, wasn't cheap. $225.00. But just to come diagnose the machine Whirlpool was going to charge $100.00 + parts and whatever else. The moral of the story is if you can tinker and be careful you can totally do this.
Jul 23, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
Fabric tray does not clear
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Nov 20, 2011 | Washing Machines
Washing Machines Logo
467 people viewed this question
Dan Webster
Dan Webster
Sal De
