Question about Sharp Office Equipment & Supplies
How do I type exponents on the Sharp writeview EL-W535X calculator?
    Genius:
  • 1,274 Answers
Http://office.manualsonline.com/manuals/mfg/sharp/elw535.html
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Posted on Nov 30, 2014
    Scholar:
  • 154 Answers
Example: 8.90809110111213e+31
informatica
  • 1114 Answers
SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Posted on Aug 10, 2007
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
vladp995
  • 81 Answers
SOURCE: how to calculate
It's very simple: the calculators have a default base 10 so that log x it's log x base 10 so here is some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
Posted on Jul 06, 2009
SOURCE: how do i display exponents besides 2, or 3 on the
EL-531W SHARP:
If you want to find 5 to the power of 6 (5^6)
you hit the 5 button, then the button that says yx ( the x is in the exponent spot) then the 6 so it will looks like this 5^6 then press enter to get the answer...hope that helps!
Posted on Sep 10, 2009
SOURCE: SHARP EL-735
There you go mate...http://support.sharp.net.au/downloads/opmanuals/EL735.pdf
Posted on Oct 04, 2009
How do i enter an exponent on the
It depends on the base of the power function.
For exponential function use [SHIFT][LN] (e^x) followed by the exponent value. If exponent is negative use the change sign +/- key before exponent.
For a general power, type in the base (number), then press the [Y^x] key followed by the exponent.
For a power of 10, use the [Exp] key. Careful here. For example to enter 1.6x10^(-19), type in 1.6, press the [Exp] key, then the change sign key +/- and the exponent. Press [=]
1 . 6 [Exp] +/- 19 [=]
Sep 28, 2014 | Sharp EL-531WBBK 12-Digit 272-Functions...
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
How do i use the percentage function?
If you want to find 25% of 500
ENTER....
500 X 25 [2ndF] % will display 125.
If you want to know what % a number is of another number like for instance...
What percentage is 120 of 400?
ENTER...
120 [DIV] 400 [2ndF] % will display 30.
If you want to increase a number by some percentage like
Increase 500 by 25%
ENTER...
500 + 25 [2ndF] % will display 625.
If you want to decrease a number by a percentage like
Decrease 400 by 30%
ENTER...
400 - 30 [2ndF] % will Display 280.
NOTE [2ndF] is the 2ndF button. Do not enter the brackets [ and ].
NOTE [DIV] is the divide button. The text editor would not let me enter the divide symbol
Jul 18, 2014 | Sharp El-w535x Writeview Scientific...
How do I do algebra on a Sharp EL-W535x?
You can do it by hand.
8x-3x=64+8=72
Thus, 5x=72
x=72/5
Jun 30, 2014 | Sharp Office Equipment & Supplies
How to plug in exponents on sharpe EL 501X calculator
Type in your base and then press the button that says y with an x as an exponent (last row of the small buttons, second from the left). and then type in your exponent.
Apr 09, 2014 | Sharp Shar El501xbwh El 501X Basic Science...
Is it possible to do exponents other than 10 on a SHARP El-W535X Scientific Calculator?
Use the y^x key (two keys up from the 7 key). For example, to calculate 8^9, press 8 y^x 9 =
Feb 04, 2014 | Sharp Office Equipment & Supplies
How to turn on math IO mode on a sharp EL-506W calculator?
For the WriteView calculators EL-W5xx, you press 2ndF MATH to open (SetUp). Select 2:Editor, then 0:view.
Mar 22, 2012 | Sharp Office Equipment & Supplies
We purchased EL-W535X sharp calculator. Want answers in decimal point as opposed to fractions. How do we change this? My son threw out the instruction manual.
on the key pad row above 7-8-9-(-) all the way to the left there is a key that says change with two arrows moving in a cicle press after each answer will change from even fraction to uneven fraction then decimal
Sep 08, 2011 | Sharp Office Equipment & Supplies
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
Exponential form
Hi - You can download the manual from the link underlined in blue below:
EL-531 W
You need to set it to "SCI" i.e. scientific mode to show the exponents:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 05, 2008 | Sharp EL-531VB Calculator
214 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
