Question about Marey Heater Corp Marey Natural Gas 2.0 GPM Tankless Hot Water Heater 1-2 Bath Hous
Ignition problem Replaced batteries and when I close the door the ignition will work and start the flame and the water gets hot. Once the water is turned off and on again it will not ignite. Have to do it manually. Not sure why.
  • 42 Answers
Sometime the batteries in the drawer fade (yes even new ones). I am asking, is that after the flow initially stops, the Automatic Start will not fire up when there is a demand for hot water (Is this what you meant when you say "The water is turned off" and "Then on again". Check the batteries for being the right way around (I Have installed them 1/2 forward and 1/2 back ward as a set, the one cancelled the other one out....my Bad....Ooops) The battery should be only needed if the power fails, but not sure about this model. Does the Owners manual say anything about no hot water? IF that was tried, you may need to call the heating / cooling techs that are familiar with this unit.
Posted on Dec 26, 2014
Bosch battery ignition gas hot water heater won't work
SORRY but when it comes to GAS appliances I can only recommend you call a repairman .
Mar 08, 2016 | Bosch Water Heaters
No hot water no flame gwh1600h bosch
Tell me more! --
Do you have any other gas appliances in the house?-- and they are firing OK? Can you hear the gas flowing when you push in on the ignition start button? -- There should be a spark as you 'snap' the button?
Remember-- YOu get no ignition of the big flame, until you have water flowing--
How old is the heater?-- Could there be come obstruction in the water flow sensing device?
Oct 13, 2013 | Water Heaters
I have a power flex 50 gal power vent model number pvg625ot6onv.. Serial number, 0932t413742. I got a new lighting element, and installed just fine but the actual ignitor keeps dropping to vacation...
Sorry to hear about your wife.
Please copy following links for Intellivent troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.americanwaterheater.com/
Clean air intake located on bottom of heater using compressed air or feather duster. Use auto inspection mirror and flashlight to see under the unit.
Age of water heater appear on label on side of tank.
Look for serial number.
Powerflex is American water heater product (AO Smith)
First 2 digits of serial number is year of manufacturer, digits 3-4 are week during year.
Nov 26, 2012 | Water Heaters
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a 1992 bounder mh ,6a6e atwood water heater.I recently replaced the coach batteries and main battery.My circuit board went bad,replaced along with eco and thermostat.My gas valve was rusty and...
First check thermal cut-off that is connected between incoming power wire and thermostat terminal. (located inside little clear plastic sleeve) Easiest way to do that is to remove it from the circuit temporarily. Just pull it off thermostat terminal, pull it apart from other end, and just connect female spade from incoming power wire directly to thermostat terminal. Then see if water heater ignites. If it does, and all works well, get new thermal cut-off. That cut-off is a safety feature in case of flame up at burner, it will shut off gas supply. It is not reset-able, just works once then needs to be replaced.
If that doesn't cure it, take a 12v test light, or a multimeter, and test for power at gas valve, when water heater is trying to ignite, or at ECO terminal where red wire runs from left ECO terminal to gas valve. If power is getting to gas valve, and you don't hear or feel it click, make sure ground connection is sufficient as well. If you have 10.5-13.5 volts to gas valve, and it's not opening and ground is good, then it's faulty and should be replaced. If it is clicking, (opening) but no gas coming through, you may have a plugged orifice on gas valve, provided you have cleaned burner tube of any spider webs or debris previously. If no voltage from red wire, start back tracking with meter or test light to other terminal on ECO, then to terminals on thermostat as well. You'll see how feed wire (short jumper) goes from thermostat, over to ECO. Remember, you will have to hold test light or meter probe at connection and have someone turn on switch to get a reading, which will only appear when it's trying to ignite. Let me know what you find.
Dec 05, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a bosch WR 400 LPG tankless, It will not start, there is some sort of ignition problem, batteries are new and it has gas at least to the regulator, I'm tired of taking cold showers, PLEASE HELP!
These hot water heaters will drive ya nuts!!! They are great when they work but a bugger to work on...
The problem may actually be the flow sensor...often they fail to sense the flow and then do not ignite....
Is it actually trying to ignite the flame???
Is the flow switch turning the heater on?
If it is trying to ignite, do you have spark?
Does the pilot light at all?
Is the flame sensor clean?
Is power going back to the control?
Is the control failing to provide power to the gas valve(s)?
All these things need to be gone through and checked off...this will get you started towards finding the trouble...
heatman101
Sep 21, 2010 | Water Heaters
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
Hello, My Rheem hot water heaters pilot light
make sure that it is pushed into the flame of pilot light good because if not it can cool off and go out.and make sure that no drafts are getting in to heater to blow pilot.like when you close or open the front or back door have someone open them while you watch pilot light to see if it flickers .
Oct 26, 2009 | Water Heaters
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Marey Heater Corp Marey Natural Gas 2.0 GPM Tankless Hot Water Heater 1-2 Bath Hous Logo
161 people viewed this question
Top Marey Heater Corp Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Marey Heater Corp Water Heater Expert? Answer questions, earn points and help others
