Question about McCall Freezers
I have a McCall 4-4070FC i need to find out how to turn on the Lights and Door Heaters?
I looked over wiring diagram and saw switch lights and heaters, but cant find them on the cabinet.
  • 3 Answers
Your light switch is white generally around frame... As for door heater it will be on as soon as you plug unit it. You can feel around door jam to see if heating... Should be warm not scalding hot. McCall was sold to manitowoc and some parts are no longer available. If you're able to do repair yourself try case parts.
Posted on Dec 10, 2014
3 Suggested Answers
  • 340 Answers
SOURCE: What will cause door heaters to trip breaker.
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. caseparts.com good luck Tom
Posted on Jul 03, 2009
  • 1253 Answers
SOURCE: TUC-48F undercounter -10 freezer, door heaters not heating
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
Go to this True web site. It has spec sheets and manuals. Hope this helps you
Posted on Sep 11, 2009
How do I replace the door light switch?
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Apr 27, 2015 | Frigidaire Freezers
Wiring diagram for Electrolux RH06FD1F
I suggest that you try contacting their factory service help. They might be able to send you a print for it or tell you what to look for over the phone.
Jul 01, 2014 | Freezers
I have a haier household freezer model #hncm035e replacing thermostat controller that connects to temperature control and two lights one red for power and one green for running. I do not remember how wires...
I could only find a diagram on a you tube video. Look for Haier Freezer Repair posted by marcibm1. He took a picture of a freezer wiring diagram just like yours only it is a bigger cu. ft. Yours is 3.5 and his is a 7.0. After you study this, if you still have issues, let me know. First thing is to determine what wires go to the indicator lights. Usually the large black wires are power in and out of thermostat to compressor. Take your time and study the diagram. Let me know if I can be of any further help.
Mar 07, 2017 | Haier Freezers
Light flickers when door is opened
it has connection problems when you open the door of freezer connecting wire turn gradually and one time comes up light normally,you repair connecting wire of lights.
Mar 23, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Specs of tev for mccall freezer
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Nov 26, 2012 | McCall Refrigeration Commercial Freezer...
I have an upright freezer Kelvinator I got it at a garage sale, we brought it home and it has sat for a while and we never tried to get it to work until now, it doesnt turn on at all no light, no sound,...
I looked at the parts diagram (GE model#FUF14SUDRWW) on Searspartsdirect. I didn't see an actual on/off switch, but it does show a temperature control switch in the inside of the unit. On some of the freezers, if you turn the knob all the way to the left, it acts as an off switch and kills the unit. It looks like the knob inside the cabinet, on the lower back right side (it could be upper..hard to tell by that diagram). If there is no knob, but an empty hole, then the knob is missing and you might have to turn the shaft with pliers to check it. If you get a click at one limit of the switch when it is turned, that means it is acting as an on/off switch. If nothing happens when turning it after the click, I would suspect a bad switch. Since the lights nor compressor are working, it would point at a switch. You can probably find it cheaper than Sears by googling the part # WR09X10064. I saw it as low as $84 at some of the appliance parts site. A local place might have a used one for cheaper.
Hope this helps
Aug 16, 2011 | GE 13.7 cu. ft. General Electric Upright...
I like the wire diagram from 3 door freezer swich to lights inside
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to "Support" and then do the "Ask the True service Dept." They will need your model and serial numbers and they will send it to you.
Jan 11, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Msf-49nm evaportor pan and drain iced up
I deal with MasterBilt which is a private lable made by TurboAir.
I have several units but only one does this icing up thing. Look for a bad seal on the door gasket. These really ice up if that does not seal almost perfectly. Look for premature termination of the defrost cycle. Check that the heater is pulling amps. The wiring diagram at "turboairinc.com" is very poor but it shows 2 heaters for the refrigerator. They list a diagram for the freezer but it's not there. I know for sure that there is a heater for the evap but don't know about the drain. I've seen some have it and some don't. there tech support line has much to be desired but it's worth a shot. Also, the bottom hinge on the door fails fairly regularly. This allows the door to drop just enought to disengage the switch at the top of the door and stop the evap fan from running, thus causing a freeze up.
Good Luck . You got your hands full with this one.
Dec 11, 2008 | Turbo Air 49 cu. ft. / 1388 liter...
Can not get temp. below +10 f
what is your superheat and is defrost cycle working
Jun 19, 2008 | McCall Freezer 7-7045FT
Freezers Logo
116 people viewed this question
Top McCall Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a McCall Freezer Expert? Answer questions, earn points and help others
