Question about Dryers
I have changed the thermal device and still not heat
I have changed the thermal device #279816 and still no heat
    New Friend:
  • 23 Answers
There are several devices in your system. You replaced the the thermal cut out designed to interrupt power when the temperature reaches 250 deg F. A thermal fuse is also installed which "blows" at 390 deg F. A third control device is the thermister which signals the control board to control air temperature. When it fails the system is designed to generate signal such as beep-beep-beep. To test the heater itself you can disconnect one end and measure resistance to determine that the heater is not burned out. Also you can read the voltage applied across the heater (if there is voltage but no heat the heater need replacing)
The control board gets a signal from the sequencing system. The manufacturer will provide a schematic for your machine if you ask.
Posted on Nov 30, 2014
What number thermal fuse and thermostat will work on kenmore elite model 11o 23032 dryer
thermal fuse 3390719
Thermal cut off and high limit kit 279816
Operating thermostat 3387134
Jan 22, 2017 | Kenmore Dryers
How do I install part #279816 which technician said replaced 3399693?
Hello. Here is the link which includes a video on how to replace the thermal fuse kit for the dryer. http://www.appliancepartspros.com/whirlpool-dryer-thermal-cut-279816-ap3094244.html. I hope this helps you.
Aug 24, 2015 | Dryers
No heat
First check the voltage and make sure you have 220 volts. Next check and see if the heating element has resistance and check the small thermal fuse at the top of the heater housing. If the fuse is trip you need part 279816/. Replace both the thermal fuse and the high temp thermostat on the side of the heater housing. They both come in the part number I gave you. .Then check and make sure the vent hose is clear and straight as possible. and you should be golden.
Jan 28, 2014 | Whirlpool Dryers
Dryer not heating mod # 110.64652400
you may have several problems, first, check the thermal cut-off with a meter(continuity) at the side top or the heating element. if not beep or mesure "0" on the display then is bad, change it as a kit#279816 part# at Sears. if is good(it beeps) then check the heating element for ohm about 10 to 12ohms. if it reads "0" then is bad, part#279838. if is good then check continuity on the thermal fuse at the blower housing(a white 2prong part) if it not beep then change ir part#3392519. all parts at Sears Website or Sears Service Center. good luck to you.
Feb 06, 2011 | Kenmore Dryers
Model RES7745PQ0 works great but no heat... what is most likely the problem... also I checked my breaker so that's not it...? HELP\r\nBest Regards
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Jan 19, 2011 | Roper Dryers
I am replacing the thermostat on my Roper dryer. Model number of dryer is RES7745RQ0. I went to a local parts supplier and I received the ''Thermal Cutoff kit'' with the part number 279769. The spade...
it may be 279816. it can also depend on what thermal fuse you are trying to replace.part # 3977393 includes both the fuses that go on the
heating element can
Sep 26, 2009 | Dryers
My dryer is a supreme 7cycle 4temp, model LER7646EZ0. No heat. Is resistance of heater coil around 9omhs? Voltage on one end of heater coil is 52 vac terminal to ground.
Set your meter to "beep" when leads are touched together . Disconnect 1 wire from element , then touch both element terminals . A beep , it's good . Touch the small "thermostat" (thermal cut-off ) terminals at the top of the heater box and see if it beeps . No beep , bad . Pt # 279816 . This pt# includes the thermal cut-off AND the hi-limit thermostat . Both must be replaced .
Jul 29, 2009 | Whirlpool Dryers
Whirlpool let7848dqo no heat
Check the thermal fuse it is on the left side of the heating element duct up about 3/4 of the way has 2 wires you can jumper it out if it heats you can buy the kit part# 279816 let me know if this does not work we can look elsewhere
Nov 30, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
