Question about Sony Televison & Video
I have a Sony KDL-42W70xB and want to set up for surround sound with an amp which has no HDMI, is this possible?
There seems to be a red and white socket on the rear of the TV, I have run cables to my amplifier with no luck. Any more help please?
    Top Expert:
  • Sony Master
  • 75,417 Answers
If there is any other audio input, you can connect it through. Contact any service technician. http://electronicshelponline.blogspot.com/
Posted on Dec 01, 2014
SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
Posted on Aug 25, 2007
SOURCE: How do I hook up the HDMI cables to a cable box
how do i hook up hdmi cables to cable Sony KDL Bravia LCD HDTV
Posted on Sep 26, 2008
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
Can't get bass through subwoofer of my old sony surround sound system when i connect my laptop to amp using 3.5mm jack. laptop is Samsung rv511 and sony amp doesn't have optical in or hdmi in. any ide
If I understand correctly, you have a 3.5mm plug into your Samsung laptop, which is then connected to your Sony surround system via the red/white RCA plugs. I assume for the input to the Sony you're using a standard audio-in. I would check the speaker setup settings on the Sony to ensure that the "bass" and not just LFE (low frequency effects) are being sent to the sub-woofer. My understanding is that LFE is found only on Dolby or DTS encoded soundtracks, and if the subwoofer is limited to just LFE you wouldn't be getting any bass when listening to two channel stereo from your laptop.
Mar 20, 2014 | Sony Audio Players & Recorders
I can not get my surround sound to work with my sony bravia HBD-E570 blue ray, while watching dish
I use HDMI cables for my blue ray DVD player, not sure if you do. If so, make sure surround sound is connected to your TV in the right jack. My surround system is old, so only uses RCA's (red, white, yellow). I plug mine into the audio out jacks (red, white) just below the HDMI 1 jack. Only the red and white are required for sound but also can use video (yellow) for higher quality. That is the main audio out. Plug into that and you should have all sound that is on your TV also sent to your surround system.
Aug 02, 2013 | Sony Bravia Kdl 46Ex700 46 in. TV
Surround sound hookup between my 2008 sony bravia and sony A/V surround sound receiver which is older.
the yellow on an RCA setup is a video signal not audio, so just hook up the yellow to video 1 and red /white to audio 1 or whatever number it happens to be
May 09, 2012 | Sony BRAVIA KDL-46V3000 Television
No sound
Check the on screen sound set up to see if the sound for HDMI mode is set for analog output (using RCA Red and White audio output jacks) or through the HDMI port.
Jul 02, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I get surround sound whenever i'm playing dvd's. But how do i hookup surround sound when just watching television? I have a 46 inch Sony Bravia LCD TV and a Panasonic SA-HT700 surround sound and HD...
just plug your satellite and dvd player in to your tv. and simply take an extra set of red, white, yellow wires and us use the red and white wires to connect fron your tv output to your surround sound system's input. now you should have surround sound for everything included local tv stations from your tv antenna
Aug 28, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Televison & Video Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
