I have an Apex pf3230 32" TV that recently shut off, no power besides a slight clicking noise. The noise seems to be coming from a large component with a solid copper band about 3/4" wide... on said component, "BCK24211L" is printed and in smaller fonts, "20030513242" is printed underneath. Is there any help you may be able to give me???
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
The short circuit protection circuit inside the set; detects a short circuit [shorted component/s]. The circuit shuts down the set; to prevent further damage to components. That is happening here. The sound you hear is from a cut of relay; which in turn switches off the set. Contact any service technician to detect the fault. Never switch the TV "ON"; until this fault has been rectified. It might make things worse. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 02, 2014
5 Suggested Answers
debroy
  • 174 Answers
SOURCE: print is too small.
r u printing from internet...? if yes then save the document before you print on your desktop or copy the document on word and then print.
Posted on Nov 28, 2008
  • 2692 Answers
SOURCE: printing w.lexmark e232 font way too small
I believe LEXMARK has upgraded the software for you printer with a new VISTA driver. Disconnect the printer, uninstall the software . Reinstall the software for you model from theLEXMARK  link I have provided you below:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Feb 08, 2009
SOURCE: Pages are printing out with solid black background w/white font
On many machines there is a "positive/negative" setting that can be set that would produce this output...check your settings.
Posted on Apr 20, 2009
  • 4 Answers
SOURCE: Diagonal shading problem on monochrome print
I would try cleaning the lasers with the brush inside the door. If that fails, you might try looking at the developers.
Posted on Apr 27, 2009
Apex troubleshooting
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 07, 2014 | Apex Digital AT3208S 32" TV
My apex tv when black and hear no sound but tv turn off and on then I trip my surge protector and sound came on and nothing else so I left it unplugged for a couple days still only sound what should I do...
There might be shorted component/s in the power supply board.
Check this site for more details. "Electro-help" is the site name. Search it by google search. You can locate it, either at the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help site in English, has more details about more brands.
Jun 17, 2012 | Apex Digital LD4088 LCD TV
Vizio vp422hdtv10a plasma tv will not turn on. Made kind of a real loud click and shut off and will not turn on again. Removed back, fuses don't appear to be blown. Circuit boards don't appear to have any...
Good call checking the fuses first. Next I would try replacing the power-board. If you have a volt-meter you can test it first, but BE CAREFUL as it would require having the TV plugged in.
The power-board is the one with the most large components on it, like transformers (coils of wire) and capacitors (tin-can looking things). The board itself will be much smaller then the main board, and may be the first place the power cord leads to.
The good news is that this is probably the cheapest component in a TV to replace (besides a fuse that is). Check online.
Mar 19, 2010 | Vizio VP422 42 in. Plasma TV
Apex converter boxes malfunction.
If the converter box wont power on and makes a cyclic whinging noise, it may be one of the 4 470uF caps on the low voltage side of the power supply. Check for domed tops on the caps nearest the fly back transformer (center of the board). I replace all four of those caps just to be sure and it is playing fine now.
Nov 15, 2009 | Apex Digital Televison & Video
Tv made sizzle pop sound and went out
All depending on the models, but i have seen and work on may units with this problem, there are a few large capacitors on the power supply that are sometimes doubly secured with glue, that in turn becomes conductive and causes faults like this. check all the large capacitors for any low or nil readings and with a fine point probe, carefully remove the glue on the and around the caos, and elsewhere if you see any. Good Luck.
Aug 27, 2009 | Apex Digital GB65HD09W 65" Rear Projection...
Panasonic TH50PX85U power shuts off and won't come on.
power board failure, common in this model, replace power pcb then check VS and VA voltage could be X or Y driver causing power pcb to fail.
Aug 09, 2009 | Televison & Video
TV wont come on
some electronic components inside your TV had shorted out! you might be hearing a slight CHIRPING! like the sound of crickets! or maybe whining! the sound migth be coming from the transformer/inductor with a shorted component on its output!
Nov 16, 2007 | RCA F32650 32" TV
My apex tv fell forward of a desk about 2 feet high
You may have cracked the circuit board. and or damaged a few components in the power supply section or the high voltage section. If you do not have a background in electronics I would suggest you take this unit to the shop for an estimate and or repair.
May 28, 2007 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Buzzing sound coming from TV
Sounds like a power supply, could be a large capacitor or a large transformer making the noise
Mar 14, 2007 | Harsper HP-4200VPM Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
