Question about Hunter Dryers
New Hunter fan from Home Depot. Fan installed by professional electrician. When fan "ON" has GRINDING SOUND. HD will replace, but not cover cost to remove & reinstall of electrician. Can the fan b
None
    Scholar:
  • 42 Answers
Fans are not difficult to replace / install. The difficult part is the lifting and support part when connecting the wiring and securing the support in place. The main safety feature is to turn off the power at the circuit breaker or fuse panel, don't just use the wall switch.
If you can get two ladders in place and have someone hold the fan while you disconnect the support from the ceiling bracket and disconnect the wiring it is a very simple job.
Otherwise, you just have to take your time and make sure to follow the instructions and connect the house wires to the correct fan wires.
If you do not feel confident, then it is best to find an electrician or handyman who can do the job for you.
Posted on Dec 02, 2014
SOURCE: Hampton Bay 326-946
Chances are the wire nut came off the connection for the light unit. If you're handy, shut off the fan mechanism at the fan (pull chain until fan is off), then turn off the power at the breaker box, ensure the power is off at the light switch and proceed to unscrew the fixture from the mounting unit (attached to the ceiling).
Carefully support the fan unit with one hand ( there should be a silver grounding wire that will help support the unit - unless it wasn't installed properly in which case the unit will be heavy - try to balance on the ladder if it's tall enough). Look for the white and black wires - one will be for the fan unit, one for the light unit.
Check to see both are securely attached by wire nuts. If one is loose or has come apart, carefully re-twist the wires tight (turn to the right as this is the way the wire nut twists on so it will stay together when you replace the wire nut. If when you replace the wire nut the wires are still loose, replace the wire nut - they do get old and tired.
At this point I would turn on the power at the breaker box and turn on the switch for the fan on the wall. Then try the light unit - see if that fixed the problem. If it has, turn off power again, replace the unit the same way you took it down - if not, there is a problem in the internal wiring . . . check with warranty depot.
Hope this helps,
Lauri
Posted on May 26, 2008
  • 25 Answers
SOURCE: Hampton Bay 73554 (56-ANT) from Home Depot
You need a new motor, are you still in warranty?
Posted on Jan 15, 2009
  • 163 Answers
SOURCE: We bought a 42
hunter will back up there fans call them and you will get help and i dont mean by fix ing it they will rweplace it dont take no for an awanser they need you more then you need them you will find that moust of these os called home improvment stores are more then happt to help GIVE IT A TRY
Posted on Jul 26, 2009
VtToolMan
  • 704 Answers
SOURCE: My Hunter 20803 ceiling fan only works at one
The part you are making reference to is a capacitor and you can very likely get a replacement one at any local Radio Shack store. It is best to take the defective part with you so they can review all the markings to get the best replacment part you need.
If the capacitor isn't connected with wire nuts, you'll want to cut the wires as close to the capacitor as possible, so you'll have some wire to reconnect the new part. I also suggest you take a picture with your digital camera or camera phone BEFORE you remove the bad part, that way, you can refer back to it, when you are installing the new part.
With any electrical device, you will want to disconnect it from the power source before doing any repair or service work on it, to prevent electrical shock hazards. In the case of a ceiling fan, you can either remove the fan from the ceiling or turn off the breaker that provides power to that room (check to make certain you got the correct breaker turned off!) Also, you can make sure the wall switch that controls this fan, if you have one, is turned "off". You can tape over the switch to remind others not to turn it on, etc. while you get the parts to make the repair.
Hope you find this Very Helpful and best regards!
Posted on Oct 25, 2009
  • 2418 Answers
SOURCE: ceiling fan problem
This fan company will warranty to 5 years. Sorry.
Posted on Jan 23, 2010
I have a Hunter fan and now the pull chain that turns the lights on and off has stopped working. What do I need to do to fix this?
You need to buy & install a new light switch. Should be a two wire switch that you should be able to find at Home Depot, Lowes or a real fan store.
Oct 18, 2013 | Hunter Ceiling Fan Light Switch Control
Hunter fan switch doesn't work
I had this same problem. Home Depot and Hunter did not help me. I called Ken's Electronics in Kalamazoo Michigan Phone (269) 345-4609
website http://www.kenselectronics.com/index.html. He was excellent and very knowledgeable. Got repair part for about $7.00 and received it within two days. Great. I was so frustrated because it looks like I was going to have to purchase and install a whole new fan. Started to wonder if Home Depot and Hunter did this on purpose. Call Ken and he can help with questions and installation too.
Dec 01, 2011 | Hunter (25417) Ceiling Fan
Where can I purchase a 3/4" downrod coupler for a
From your friendly neighborhood electrician - any electric supply (a business supplying parts to
the electrical & HVAC trade) will either carry Hunter parts, or at the very least be able to
order the parts - why: Hunter is manufactered in the USA. Nearly every other brand of ceiling
fan you'll find at your neighborhood Home Depot or Lowes is manufactured in China.
The typical ceiling fan will come with parts for two configurations: (1) flush, and (2) a optional
3-inch downrod, but commercial installations will somtimes use extended downrods.
The Hunter web site (http://www.hunterfan.com) catalog shows available downrods in several
lengths: 12", 18", 24", 36", 48", 60", and 72".
I found Hunter downrod specifics in the online "core products catalog," at:
http://s7d5.scene7.com/s7/brochure/flash_brochure.jsp?company=HunterFan&sku=Core_2011_Trade_Final&config=HunterFan/skin&locale=en&zoomheight=600&zoomwidth=800
May 30, 2011 | Hunter Dryers
The fan chain does not pull smoothly ,had to use string
if its an old fan the switch may be worn out an electrician can replace it most places like home depot offer some kinda replacement part for not much money. replace it yourself if you can do it safely remember electricity kill
Mar 30, 2010 | Hunter 20479 The Stratford II Ceiling Fan
Ceiling fan problem
Jan 23, 2010 | Hampton Bay 24002 Ceiling Fan
I have a Hunter model 21241 ceiling fan with circline fluorescent light. The light module is a VEB82122 (ballast "A"). This is part of switch housing assembly part number 93563-09-000. I get a dim...
The ballast is still available on the internet, just Google "veb82122." They want $37 plus shipping. You can also but a 22W Circiline ballast at Home Depot that will work for about $18. (Lowes does not carry them). The original ballast is a solid state design, light weight and instant on. The Home Depot ballast is the heavy transformer kind and a real pain to modify the bracket to make it fit. I have 8 of these Hunter fans and I have installed the Home Depot ballast on two if them so far, but I think that I will order the solid state version as a spare for the next time.
Aug 13, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
Fan & lights doesnt work
If you can find the exact fan at Home Depot, purchase it and return the lemon that you have. I cannot find a hampton bay website. Home Depot apparently buys these directly from overseas manufacturers, so there is no "company" to contact for real support. I had no luck finding my capacitor C61 E185116. Stick with the big names like Hunter in the future. Believe it or not, I received a free trim ring for mine about five years after purchase because it kept falling onto the body. Now that is world-class support!
Jul 16, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
Dryers Logo
63 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
