Question about Measuring Tools & Sensors
We have two people living in our house and we are using 2 bags of salt a week. How can I cut this back.
Lowering the float to the bottom of the tank.
    Scholar:
  • 154 Answers
Eat Less Salt
Posted on Nov 30, 2014
How can I prevent my Saltwater aquariums from accumulating so much salt on the outside of the tank.I have to clean saltwater build up at least every 3 days.I have a 125 Gallon and also a 55 Gallon Sal
I am no expert on saltwater tanks, but I am wondering what temperature you are keeping the tanks. The water evaporation rate of the tank depends on the temperature and humidity of the room the tank is in. Lowering the tank temperature to around 70-72 `F and increasing the ambient humidity to 60+% RH will reduce evaporation which will result in less salt encrustation.
Nov 28, 2014 | Fish
Culligan n8 black hose fell off and water was flowing out until i turned off the valve how and where do i re attach thx
If the "black hose" is about 1/2" in diameter it attaches to the drain elbow on the left side of the valve. Use a hose clamp, cut some of the drain line back (about 2") slide it back on the drain elbow and clamp it on the elbow.
If the black hose is 3/8" it attaches to the fitting on the salt tank, which attaches to the float.
If it broke because it is brittle I would go to any water treatment dealer and get a new piece of "brine line" to replace it.
RJ
Oct 10, 2011 | Culligan Under Sink Water Filter
Cullihan water softener-No water in tank-Orange water in house-Salt level measured 3 months ago, has remained the same. ( no salt used ) Repair man claims to have fixed the timer 45 days ago.
the way a water softener is set by , goes off the hardness of the water and how much water you use. Doing a manual cycle will show you if its at least working or not. If nothing happens when you do a manual cycle then you should call back the repair man and have him look at again. The float might be stuck in the brine tank, you can try emptying the salt and cleaning the salt tank out side with a hose, spray water in to the float and make sure is clean and free . Add salt with 3 gallons of water and do a manual cycle. If this still doesn't work then it could be a stuck valve inside the water softener that is stuck closed.
May 18, 2010 | Plumbing
Aftre the unit regenerates the water is not replenished in the salt tank?
At the top of the float assembly in the brine tank is a round nut that unscrews. Be careful when pulling this out. The refill flow restrictor is inside this part. There is probably some debris plugging the refill restrictor so it is not re-filling the salt tank with water. Also take the float assembly out and clean it thoroughly. The slots at the bottom where air check sits can become plugged with iron and restrict the refill. If all of this is fine check the eductor/injector assembly. From there it is the refill piston that may be at fault.
RJ
May 05, 2010 | Culligan Sediment Water Filter
Mine is a Bruner series 400. I used to add
Start by calling your local utility company and ask them how hard the water is , then set it from their.
Mar 25, 2010 | Plumbing
I inherited a water softener system with the house - I do not have any manual or cannot see the name anywhere. It worked fine for 4 years and now it's stopped and do not know what to do? We added the...
There are a number of things that it could be. The main problem is that the softner is not sucking the brine into the tank. It still ran water into you tank till the safety shutoff stopped it. This made all the salt turn into a big lump. You will need to find out why the unit does not have suction when it is in the "brine and rinse" mode. Probably either the float in the brine tank is stuck or there is dirt in the screen at the top of the hose out of the brine tank that is stopping the brine from being sucked up the hose. First empty the tank and then you can see what the unit is doing from there.
Nov 16, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
We switched to the saltwater system and the water is cloudy after 2 days
DID YOU USE POOL SALT, MINE STAYED CLOUDY FOR 2 WEEKS AND FINALLY CLEARED UP , I USED THE WRONG SALT , 25LB BAGS OF TABLE SALT FROM SAMS CLUB
Jul 18, 2009 | Intex Automatic Salt Water System for ...
I don't know how much salt is needed for my 18x6 pool 3 bags have been added and the system keeps beeping more salt needed.
keep adding salt.(1 to 1/2 bag at a time - let mix in for an hour - re-test)
If you live in high rainfull areas - you will need to add about 1 to 2 bags of salt after every heavy rainfull.
Jun 30, 2009 | Intex Automatic Salt Water System for ...
Problems with reverse osmosis water treatment system
http://www.ag.ndsu.edu/h2oqual/watsys/ae1047w.htm Treatment systems for household water supplies gives a great description for reverse osmosis systems. I am not familiar with the Maruyama system since I live in the states. After reading the above article you might want to test your water. Your system may be operating properly? To me it soulds like you have a water softner and flushed the salt out, and now you have the proper pellets? If your water is not very hard you shouldn't use too much salt. Building supply stores sell cheap water test kits. Try that, and if your water tests ok, and doesn't smell, and lathers up with soap sounds like everthing is working ok. Hope I helped
Apr 24, 2009 | Mountain Plumbing AG600S Air Gap for...
Have a 30yr. old mark 20 culligan water softner which still works
You should not have to adjust the brine setting. Just the days per week. The salt dosage is dependent on the capacity. If you cut back on the days used you will still need to use the same amount of sodium to regenerate the softener.
RJ
Apr 03, 2009 | Culligan Sediment Water Filter Heavy Duty
Measuring Tools & Sensors Logo
67 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
