Question about Poulan Garden
I RECENTLY HAD A PROBLEM WITH A POULAN BVM200FE LEAF BLOWER NOT OLD AT ALL WAS WORKING IN YARD AND BLOWER JUST STOPPED WORKING I HAD FUEL BUT NO SPARK I REPLACED COILPUT IN BUSINESS CARD FOR GAP AND S
Has gas,new coil aftermarket,wires are ok,plug isnt new but i check the spark with a screw driver against head,i cant seem to get spartk i was going to get a new coil maby the new one i bought was bad.
  • Poulan Master
  • 1,169 Answers
First let me say I don't know of an aftermarket coil made for this blower.
Disconnect the kill terminal of coil and see if it is generating a spark. There could be a short the wiring if it is now generating a spark. Also make sure coil has a good electrical ground to the cylinder. If coil is not generating a spark with kill wire off and the coil to cylinder ground is good then coil is most likely bad.
Posted on Nov 30, 2014
Testimonial: "I did exactly what you said to do and still dont have spark i just cant believe that a new coil came threw bad,i guess it could happen"
  • 149 Answers
SOURCE: poulan pro bvm200 leaf blower/vac won't run on high
Is the exhaust spark arresor screen clean? a blocked exhaust will do this.
Posted on Jan 08, 2009
  • 15 Answers
SOURCE: Poulan Pro 200 Leaf Blower won't start. I have
Ok. Good job on doing what you could, right off! The simplest things are the most overlooked, and the most unforgiving.
So, you know your plug is wet, so you got some fuel flow.
Now let's figure out the plug no-fire problem. (This is under the assumption you haven't beat on this blower with a sledge-hammer at one point. The whole "key-way" is fried thing.)
1. Grab ahold of that plug THEN crank away. One time will tell you yes or no on spark. No, I am not joking, and yes, it is better than staring at the end of a plug and wondering if your eyes are bad.
In fact, better than a cup of coffee......in a bad way.
2. Check your kill switch. It is either: Grounding, or Open (open like it should be, UNTIL you push it, click it, or slide it, whatever you got). One CHEAP and fast way: Unhook the kill switch.
Then crank away. No spark? Not the kill switch then!
3. Check your spark plug GROUND. Let's say you got some shocking results from grabbing onto that bad boy. NOW check where the plug meets the cylinder head when she is screwed down in there. Believe it or not.....if it is funky, she won't ground right!
Hence, no worky.
4. You got no spark at all.....STILL. Let's look over your Spark Plug WIRE. Is she wore through? Is SHE grounding out? Has she heat failed? Then do #5.
5. STILL no spark. Let's check the last 2 things......
Rotor Magnets, and Magneto (ignition coil).
IF you have a volt/multi-meter, hook her up to the plug wire. No juice = Bad Magneto, or Bad Plug Wire. SOME juice = Good Magneto, but Bad Plug Wire (in some mowers/weedeaters, etc., remember that the Magneto is where the kill switch hooks too.
See if it is somehow grounding you out, by being loose but still touching the cylinder, etc.)
6. Failing Magneto. This can happen, and it does. You get SOME juice, just not ENOUGH juice. 2-Strokes make a lot of heat, even Magneto's give up the ghost after a while, sometimes. In this case, find a replacement!
Posted on May 30, 2009
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
Dolfoff
  • 148 Answers
SOURCE: Echo Blower PB-403T will not start. I replaced the
Should be two fuel lines coming from fuel tank grommet. One feeds the carb's primer plate and the other returns from the same. Open the fuel tank and observe while pressing the primer. If you see fuel pumped INTO the tank while pushing the primer and pulled FROM the tank when the primer is released, you're OK. If not, the lines are backward. Filtered line is on SUCTION side of primer bulb. Unfiltered line is on PRESSURE side of primer and is simply a return to the tank.
Next, concerning the coil: Air gap should be .010 inch at the magnet. Echo ignition coils are warrantied for life to the original purchaser, so don't tamper too much with it. Check gap and check fire with a spark tester. If no spark with switch in on position, take it to an AUTHORIZED SERVICING dealer, found here.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 468 Answers
SOURCE: I can't get my Poulon leaf blower to start
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
Posted on Mar 25, 2010
How do I fix my Poulan Pro bvm200fe?
If you do indeed have (good)fuel and spark to cylinder, I suggest you remove muffler and clean the internal screen/mesh and carefully scrape off carbon around exhaust port. Do not let debris fall inside engine when cleaning.
Repairing my STIHL FS 38 Clogged Muffler Fix
How To Troubleshoot Your Weedeater to crank every time
Feb 20, 2016 | Poulan Pro 25cc 2-Cycle Gas Blower...
My 2 yr. old Poulan Pro BVM200FE blower won't start. It will turn over a few times after 3-4 pulls then nothing.
replace the spark plug, make sure the air filter is clean, make sure it has fresh fuel. if it still wont start. give a shot of carburetor cleaner straight in the carburetor it should start and run for a few seconds. if it does. the carburetor needs to be cleaned. hope this fixes your problem, good luck
Aug 14, 2015 | Poulan Pro 25cc 2-Cycle Gas Blower...
My Poulan BVM200FE blower has no spark, what could be the cause?
Coil, spark plug, or off/on switch is grounded.
Oct 02, 2014 | Poulan Garden
How do you adjust the carburator
Initial start is 1 full turn out on both low and high setting.
Sep 25, 2014 | Poulan Garden
Poulan pro blower will not build up blower speed
start it up and at full throttle adjust the hi speed carb jet to get max speed.
Oct 30, 2013 | Poulan Pro 25cc 2-Cycle Gas Blower...
Losen piston ring
work a screw driver of similar tool into the ring gap and pry the ring out. You may want to soak it in a carbon disolver solution overnight first.
Aug 17, 2013 | Poulan Pro 25cc 2-Cycle Gas Blower...
What is the compression on a poulan bvm200FE blower
It has lost compression, I just repaired two that were doing the same thing, Installed a new piston ring in both and they fired up and ran great on the second pull. Also check to be sure the bolts haven't backed out that hold the cylinder jug on to the block, this will cause it to lose compression and not start or run either. A new ring costs $2.00 and can be installed in less than an hour.
Sep 08, 2012 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a weed eater blower bv1085, It just stopped. I have changed the fuel filter, air filter and plug but it still will not start any suggestions
Put a spark tester on it see if you have spark,if not.its your coil,would probably be cheaper to buy blower at yard sale than buy a coil. If tou do have spark order a rebuild kit for your carb.When you take the carb off and clean it,look real close,there will be a number on the carb,you need that number to order the right kit,all carbs on weedeater brand equip. are like that.
Aug 01, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
265 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
