Question about Samsung HL-T5055W Compatible TV Lamp
I needto know where the temp sensor is on a hl-t5055w
Nothing
    Master:
  • Samsung Master
  • 687 Answers
It is located above the lamp housing
Posted on Jan 31, 2015
I have a dacor erd30 with a code of fo. what do i needto fix it?
Try looking in the user manual for the code explanation.
Contact Dacor if it's not.
Try shutting off the breaker for a few minutes to see if the code clears.
Did the code appear after a, "Clean" cycle?
Jan 12, 2015 | Dacor Kitchen Ranges
I replaced the pump motor on my hot tub. After replacing it, the motor would not come on. I ended up replacing the circuit board. The motor now comes on, but when it starts to heat I get a HL code. I...
Balboa switched to using two temp sensors a few years ago. So you won't find a flow or pressure switch. One of your temp sensors may be bad. With out knowing which pack you have I can't do much else for you.
I had a few issues with retro fitting these packs in older hot tubs. If the sensors read more than 2 degrees in diffrence the pack will either give you a flow or overheat message. Depending on witch one reads higher. Try swithing them by swapping them where they plug in at the board. If your still getting the same error you may have a flow issue. If this proves to be the case you can plumb in a by-pass allowing some of the water past the heater. It's not recommended by balboa but has solved their temp sensor errors for me in the past.
Also try putting it in test mode. You'll have to look up how to do it for your model. This is done with a dip switch on the board. Then read what the temp reading on temp sensor one and two is. If the reading are more than 2 degrees apart and your absolutly sure the sensors are good create a by-pass. This will solve the issue. Also be sure to put a ball valve on your by-pass to allow for ajustment so that you can get the maximum flow thru the heater w/ out getting the HL error.
Oct 10, 2013 | Pool & Spa
My samsung hl-s5088w wont turn on
find and test the main fuse in this set first.
Dec 08, 2012 | Samsung HL-S5088W 50" HDTV
The HL indicator light comes on and I can not get it to reset. I shut spa off and the HL light was on again when I checked an hour later. I live in Wisconsin and don't want my tub to freeze. Tub was used...
It sounds like a flow issue. When the HL comes on, its sensing a higher temp than it is supposed to. This is usually caused by bad flow in the circulation pump.
The most likely cause of the bad flow in residential spas, is a bad filter element. Even if a filter looks clean, they do get clogged with particles we cant see. To test this, make sure the spa is free of debris, and remove the filter element. Run spa for a while and see if the code comes back. If it doesnt, get a new filter.
Otherwise the pump could either be failing, or clogged. Check this next.
Finally if these dont work, check the temp sensor (thermistor) .
Jan 24, 2011 | Arctic Pool & Spa
I have a cyote spa hl code is on..and temp is cool at 96 ,,i unplugged for 10 min,,reset the f cycle from 6 to 4 ,,,,,nothing,,
This probably means the the circulation pump is failing. It sounds like the temp sensor is good, but the high limit sensor is either bad or really reading a high limit. This is very typical of a small undersized circulation pump that is starting to fail.
Aug 29, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Tv will not stay on
You lamp a new lamp. You can find the lamp part number on the side of the TV. If you want to learn more about your lamp, you should have a look at my Tips & Tricks. I hope this was of some assistance.
Mar 28, 2010 | Televison & Video
Temp sensor
Bypassing the temp sensor may cause a FIRE!!! I don't recommend this.
Aug 14, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-T5055W Compatible TV Lamp Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
