Question about Eddie Bauer Baby Gear
I bought an Eddie Bauer infant swing 2nd hand and it won't swing. I put new batteries in but still it won't do what its suppose to. Any ideas?
This model plays 10 different tunes and has adjustable swing settings.
  • 1,548 Answers
Does it play the tunes? If not, verify that the batteries are installed correctly. If that is not the problem, read on:
I don't know about your particular infant swing, but those I have seen use a vibrating motor to drive the swing. This a small electric motor with an intentionally out of balance weight on the shaft. When it spins, the whole assembly shakes. The drawbacks to this design are that the weight may come loose so the motor spins without turning the weight, the wires to the motor may break off from the vibration, or the motor bearings may go bad from the heavy wear.
You would need to open the housing to see what the problem is. A broken wire is usually easy to repair if you are good with soldering. A loose setscrew on the weight can be secured with a thread-locking compound. A worn motor bearing, on the other hand, cannot be economically repaired. (The shaft of a worn-out motor will have a lot of side play - if it's worn to the point of failure, the armature inside the motor may drag on the field magnet and be hard to turn, or the motor brushes will not make proper contact with the commutator.) These motors are generally very common varieties and are available from Jameco Electronics or Radio Shack. For example, Vibrating Motor 3 Volt DC 75 mA is $3.25 plus tax and shipping.
Posted on Nov 30, 2014
  • 126 Answers
SOURCE: eddie bauer rear/front facing manual
Dorel Juvenile Group is the company you contact for any thing dealing with eddie bauer
Misplacing product instruction manuals can be such a headache. That’s why a downloadable version of many of our instruction manuals are available right here online. Simply fill out the form below and click Search!
link: http://eddiebauer.djgusa.com/instructions/
call for help: (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays)
Posted on Apr 24, 2008
  • 48 Answers
SOURCE: Missing Instruction Manual
try the manufacture website at this link
http://www.coscojuvenile.com/instructions/
you will need manufacture date and model number and you can view them online
Posted on Aug 07, 2008
  • 25 Answers
SOURCE: how to install infant car seat
The two clips are both for the LATCH system - they're not top tethers (which go to the back of the seat for forward facing seats only).
You need to choose EITHER the LATCH installation OR the seatbelt installation - doing both together can put too much stress on the belt path of the seat, causing the plastic to weaken.
If your car has the LATCH system, there will be two metal U-shaped anchors in the seat, where the seat back and the bottom of the seat meet. Some cars only have them for the side seats, not the middle, so check your car's owner's manual - if you don't have them specifically for the center seat, you'll have to either install with the seatbelt or put it in a side seat to use the LATCH - don't try using one anchor from each side, as they won't be the proper distance apart.
If you'd prefer to use the seatbelt to install, kneel with all of your weight in the seat to tighten the seatbelt. It's tight enough when it can't move more than 1 inch from side to side if you grab it at the belt path and pull it back and forth. You probably will still be able to pull the TOP of the infant seat back towards the back of the seat of the car - that's not a problem - it helps the seat to cradle the baby through an accident.
You need to have an owner's manual, though - to request a copy, contact their customer service at consumer@djgusa.com or call them at 1-800-544-1108.
Posted on Feb 18, 2009
  • 45 Answers
SOURCE: Eddie Bauer Booster Car Seat 22-880 how to take covers off
The manufacturer's instructions are the final authority - don't trust anyone else giving you instructions! Here are the links to download Dorel/Eddie Bauer carseat instructions:
Canada:
http://www.eddiebauer.djgusa.com/can/eng/instructions
USA:
http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Posted on Mar 25, 2010
  • 8 Answers
SOURCE: I own a Eddie Bauer
Check this link
Posted on Nov 02, 2010
How to open battery compartment on eddie bauer headlamp
Pull on the back piece where the strap attaches. Straight out. It appears! Do the opposite to get it back on. Make sure it's on securely or the batteries will shift out of position and you will be left in the dark.
Feb 12, 2014 | Eddie Bauer Hurricane Ridge LED Headlamp...
I have a '04 Eddie Bauer infant carseat-carrier I
Best to contact Eddie Bauer customer sevice about how to fix the straps and buckles:BY PHONE
24 hours a day 7 days a week
1-800-426-8020
BY MAIL
Eddie Bauer Customer Service
P.O. Box 7001
Groveport, OH 43125
For Hearing Impaired Service:
TTY 1-800-462-6757
M-F 7-3:30 EST
Feb 02, 2013 | Baby Gear
Need a base for eddie bauer infant car seat model IC-048
I would recommend contacting Eddie Bauer directly to find out what base works with their Infant car seat, model IC-048:
BY PHONE
1-800-426-8020
BY MAIL
P.O. Box 7001
Groveport, OH 43125
TTY 1-800-462-6757
M-F 7-3:30 EST
To e-mail Eddie Bauer: http://www.eddiebauer.com/custserv/ask_eddie_email.jsp?sectionId=24448
Jan 23, 2013 | Eddie Bauer Baby Gear
I have two cars and one of the cars has eddie bauer delux convertible rear facing. my son's 4 months old and his head keeps falling form side to side when he's asleep. is there any solution or do i have to...
hi
have you seen these they are really useful for this
http://baby.shop.ebay.com/Car-Safety-Seats-/66692/i.html?_nkw=infant+head+support+&_cqr=true&_nkwusc=infant+head+supprt&_rdc=1
Oct 21, 2010 | Eddie Bauer Baby Gear
I have the Eddie Bauer Classic Wood Swing that wont swing. The music still plays but the swing function will not turn on. I replaced the batteries just in case and that still did not help. What could be...
take apart the side with the on and off switches take apart the swing arm, remove the plastic cover over the motor look at the
blue wire from motor thru the plastic all the way to the contrl board prob broken where it goes thru plastic from motor looks like it happens alot
Sep 07, 2010 | Eddie Bauer Baby Gear
What infant car seats are compatible with an Eddie Bauer Vector
I read on anothe site only the eddie bauer infant seat is comp
Feb 15, 2009 | Eddie Bauer Glacier Vector Jogger
Eddie bauer infant carseat that is a part of the travel system
Dec 19, 2007 | Eddie Bauer 22-625-BLD
Baby Gear Logo
147 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Joyce Nokleby
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
