Question about Seiki 39" Class 4K 120Hz LED Ultra HDTV - SE39UY04 ENERGY STAR&174;
Can i hook up a seiki model SE39UY04 to a comcast HD box useing only the HDMI cable and which slot on the TV do I use
I used the HDMI cable included in box but i cant find any channels
    New Friend:
  • 8 Answers
You should be able to. You should be able to hook the HDMI cable into the tv, than go to "TV Input" and select "HDMI 1" "HDMI 2" or "HDMI 3" depending on which input you used
Posted on Nov 30, 2014
Trying to hook up my panasonic tc-p50c2 to comcast hd digital cable box and cant get it to work with hdmi cord..nothing is showing
Use only the hdmi cord to hook it up and go to menu on the tv and select hdmi for hook up and you should get a picture. Make sure your cable cord is the only cord running to the cable box , you don't need any other cord.
Feb 09, 2011 | Panasonic TCP50C2 50 in. TV
How do I hook this up to a COMCAST Cable Box...or do I hook it to the audio of the TV? Are cables the best or should I just buy an HDMI cable?
Cable (and any source) audio should go digitally and directly to your AV receiver. HDMI would work, too, but the TV would be the best place to send the HD video if you only have the one HDMI output at the Comcast box.
OTOH, I compared both HDMI and the component video hookups to my HDTV and could not see the difference. So I run my BD on HDMI (because it is by FAR the best video the TV will ever get) and component video from the HD cable box to the TV (because all broadcast video is bit- and bandwidth-limited somewhere along the line).
TV audio almost never originates with the TV unless it has an antenna, so why would you want to feed its audio to the receiver?
Aug 19, 2010 | Audio Players & Recorders
Hookup the comcast hd box to my new lcd tv?
You can use either component (Red/Green/Blue video and red/white audio) or HDMI cables to connect the Comcast HD box to your TV. Most times you can get these cables for free at the Comcast front counter.
Sep 26, 2009 | Onkyo TX-SR606 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Hdmi cord
the HDMI cable sends all the audio and video down one line, and unscrambles scrambled high def content when required, and fits in the rear of the tv, the slot looks very similair to a usb slot.
If you cable box has an HDMI slot you can use that instead of a scart lead and choose HDMI on your tv output
Aug 18, 2008 | Olevia LT37HVS 37 in. LCD HDTV
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
Apr 24, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Seiki 39" Class 4K 120Hz LED Ultra HDTV - SE39UY04 ENERGY STAR&174; Logo
171 people viewed this question
Top Seiki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Seiki Audio Player and Recorder Expert? Answer questions, earn points and help others
