Question about Energizer TUF2AAPE Hard Case Pro Flashlight
How do I change a battery on an Energizer TUF2AAP
    New Friend:
  • 8 Answers
Unscrew tailcap and pull out a battery module. Load 4 AA cells into module and re-insert.
Posted on Nov 30, 2014
How to change lightbulb in hard case energizer flashlight?
Hello, Lori -
There is more than one style of Energizer Hard Case Flashlight.
- Professional Mult-Use Light
- Professional LED Task Light
- Spotlight
- Professional LED Inspection Light
- PivotPro Light
- LED Work Light
- LED Magnet Headlight
- Professional Rugged LED Headlight
Which one are you asking about?
Without knowing which model your question is about, I suggest you contact Energizer Customer Service and ask how to open your flashlight model to change the battery. This is the link to the Energizer Contact Us web page:
https://energizer.custhelp.com/
Best wishes.
Jul 01, 2018 | Energizer Camping, Backpacking & Hiking
I changed the batteries positive to positive not working.
Put the batteries in positive (+) end first, continue putting the batteries in where the positive touches the negative (-) end of the previous battery.
Nov 18, 2016 | Energizer Camping, Backpacking & Hiking
How to change batteries energizer in421
It's easy, you don't have to remove any screws, just rotate the bottom of the base and it will open
Jan 22, 2016 | Energizer Camping, Backpacking & Hiking
Change the battery in the hard case
Start by unscrewing the lense cap retaining ring. Pinch and remove the clip from the negative (-) spring on the battery. Remove battery and slide new one in. Reconnect wire connector in between spring on the negative side of the battery. Note: some lanterns have a v'd plastic ear on the back of the reflector so when you go to screw the reflector back on, align the v'd ear with the plastic bar inside the case under the handle and slide it together until you can screw the retainer ring on.
Feb 28, 2015 | Energizer Camping, Backpacking & Hiking
Energizer CH2PC-UK battery charger' how long do i charge AA and AAA batteries
Charge time depends on the mAh capacity of the batteries (should be listed on the package, or the side of the battery) most AAAs are under 900mAh so 2 hrs should be sufficient, but AAs vary greatly in capacity so heres a link to check after you look up your mAh rating
http://energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Jan 14, 2011 | Energizer Rechargable Battery with Charger
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
What is the right battery to Minolta XG-1?
Hi
check the following
Energizer 3V Lithium Camera Battery - EVR2L76BP
Energizer Silver Oxide 1.5V Watch Battery - EVR357-303TS
Duracell 1/3 N-Cell Lithium Battery 1 Pack - DL1/3NBPK
Energizer Silver Oxide 1.5V Watch Battery 3-Pack - EVR357BP-3
Cheers
Tejodhar
Jan 04, 2010 | Konica Minolta Photography
New camera at Christmas. Low Battery always on. Using Energizer Rechargable 2500mAh. Third set of batteries.
try energizer lithium batts- some cameras very very strange about batterys-have a sony that will only work w/ sony or energizer lithium-bought all other types and they do not work-i get 300-500 pics per set of lithiums-good luck
May 13, 2008 | Cameras
Energizer TUF2AAPE Hard Case Pro Flashlight Logo
178 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
weirdtop
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
