Question about HP w17e Monitor
<!-- from fixya rte -->How do I open a w17e monitor - HP w17e Monitor
    Novelist:
  • 242 Answers
As with all monitors which are flat screen types, you need a couple of tools for the job. First a Phillips head screw driver to remove the screws from the mounting pillar and any case screws. Second you need something like a small putty knife (plastic if you can find one (cheapies at Lowes or Home Depot for example).
The case is opened by sliding the putty knife between the front and rear case halves angling from the rear to the front to gently rock the case latches loose on the inside where you can not see them, working your way along the case sides, either clockwise or counterclockwise around the screen perimeter.. just make your way around, one latch at a time.. Also, do not pull the halves apart as you make you way or you risk either rounding the latches off or breaking them all-together while disconnecting them. Be careful around the bottom front since this is where the control keys are normally located for the monitor (on-off-menu-etc.). The controls should come off with the front half, and the cables are usually pretty tiny and fragile - FYI. Once you get inside, you will see the power supply mounted to the back of the screen assembly. At this point it you should be back in normal looking territory once again to begin whatever repair you are after now. To put back together, you simply "snap" the two halves back together (you will hear the obvious "clicks" which indicate the latches are snapped into place once again (going together is much easier than taking apart, so be sure all is working before putting back together.. just sayin').
We professionals use a glorified putty knife affectionately known as a "MAC-cracker", which was sent out to service people working on the old Apple systems which were snapped together like this a long time ago.
Posted on Dec 01, 2014
The speakers on the front of my HP w17e monitor used to work, until I connected seperate speakers so I would not blow out the monitors. Today I did not plug the seperate speakers in, and I can't get...
Check the audio jack plug from monitor to cpu if connected correctly. The audio jack plug should be connected to the sound card for audio out. You can also check if the volume in the monitor is adjusted or mute
Jun 27, 2011 | HP w17e Monitor
How take apart hp w17e flatscreen
hp website will have manual to download and diagrams
Nov 04, 2010 | HP w17e Monitor
W17e Monitor: Is there aLinux driver for the HPw17e monitor?...
Hi, unfortunately compatible driver for this flat panel monitor for Linux is not available in the HP site hence it is not available.
May 18, 2010 | HP w17e Monitor
My w17e monitor says "input not supported"
Not quite sure what the question is that you have not already answered for yourself.
That monitor's maximum resolution is given as 1440 X 900 at 60Hz and installing a more powerful video card won't change that.
http://reviews.cnet.com/lcd-monitors/hp-w17e-lcd-monitor/4507-3174_7-32735619.html?tag=mncol;psum
JOAT
Sep 29, 2009 | HP w17e Monitor
HP w17e monitor
i had this problem as whell for the HP w17e or maybe others, you turn off the monitor then press and hold the menu button and while you are still holding the menu button turn on the monitor and hold it still for 2 seconds and you are done. Hope this helps
Feb 18, 2009 | HP w17e Monitor
Identify cable & where to connect to get audio on HP w17e monitor
male mini-stereo to male mini-stereo
Plug into LIME GREEN port on computer.
Dec 28, 2008 | HP w17e Monitor
Widescreen format
Try setting the resolution to 1440 x 900. This worked for me.
Aug 27, 2008 | HP w17e Monitor
HP w17e monitor
buy a new computer
Mar 13, 2008 | HP w17e Monitor
HP w17e Monitor Logo
62 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
