Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Light won't shut off
A bulb blew, and after that the light was stuck on it's brightest setting and won't shut off.
I opened up the rangehood (which is actually the same unit marketed by Sears/Kenmore) and banged around the various relays with a screwdriver (hoping for dumb luck), to no effect. The controler is $150, which almost makes it as cheap to buy a whole new unit. Is there a way to replace individual parts on the controller? Is it, in fact, the controller and not one of the transformers (that seems like a long shot).
  • 38 Answers
I have never reaplaced anything on the control board. But it is definetly the control board that is defective.
Part# R111638 = $110.00
I do service calls for broan-nutone.
Inventex.com
Posted on Jun 14, 2008
Light bulb burned out
Did you have a hinge kit recently replaced? If so call them back they missed something. If not, look into the light circuit a if it goes to ground this light issue would happen. Most of these issues I found in the upper section behind the upper grills. I hope this helps
Dec 25, 2013 | Viking Professional VCBB363SS Stainless...
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
GE model 26 we changed the bulb and light still is not working..what can it be?
try checking for a stuck "off" switch around the door or where the door latches, or could be loose wiring, Do Not open up the guts of a microwave unless you know what your doing, you can seriously hurt or even kill yourself.
May 09, 2012 | GE Microwave Ovens
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
The lights on the under side of the rangehood do not work .i have replace the bulbs ,the exhaust fan works ,is their a re set switch
could be a blown transformer to supply the correct power to the lights or a loose connection on the light holders.
Aug 23, 2010 | Ovens
Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
Kenmore 63682300 Bulb blew now lights won't turn off
See if I get what you are saying.Sounds like the light switch is bad.That would be the first thing I would check.
Mar 14, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Controller failed when a bulb blew
Control Board: Part # R111638 = $110.00
I do service calls for Broan-Nutone
Inventex Inc
Nov 12, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
344 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
