Question about Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Running on hot wash
  • 56 Answers
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Posted on Nov 30, 2014
BIKER T
  • 909 Answers
SOURCE: Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Posted on Sep 18, 2009
  • 35 Answers
SOURCE: is the Bosch Classixx Dishwasher hot or cold fill
Cold fill only
Posted on Jan 03, 2010
  • 457 Answers
SOURCE: Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Posted on Feb 26, 2010
  • 457 Answers
SOURCE: Bosch Logixx dishwasher gets stuck on either wash
you have a bad control module. send me a 4 thumbs post if this was helpful to you.p.s im a old bosch tech
Posted on Feb 28, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher runs long.
Welcome to FixYa.
Based on your description
I'd say the issue actually with the control...unfortunately.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours, though many not included here still suffers from the same problem...you'll need the serial number too. Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning and obviously no "extra" heat ( aside from the water inlet temp. ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Jan 03, 2011
Problem heating and water getting hot
You have a faulty element. Please replace it.
Mar 12, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx dishwasher fault
it can be a dry joint on the electronic board, or a defective thermostat, or the element, or an interrupted wire in the lower point of the door
Dec 23, 2013 | Bosch Dishwashers
Water comes into dishwasher cold. why???
Welcome to FixYa.
Have you insured the unit is connected to a hot water supply line ? The water will not heat until it start's to circulate and activates the "flow switch" in the Bosch dishwashers.
If it is connected to a hot water supply, try running the hot water at your sink taps before turning on the dishwasher. If you still do not have hot water, check your hot water heater or supply.
If it is indeed connected to a cold water supply it will work, just be prepared for very long wash cycles since the Bosch machines will heat the water at a rate of 2F per minute...it could take a long time to reach 155F.
Let me know what you find out and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch classixx washing machine is not heating the water
Have you interchanged the hot and the cold water valve? Check your installation. If the installation is correct, the hot water valve might be the problem. You probably need to replace it with a new one.
http://www.washingmachineadvisor.com
Nov 09, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx dishwasher saying check water also not washing or spining
Bosch dishwashers have a food filter to catch food particles. You have to clean it occasionally, or it plugs up and stops water flow. This could be your problem. (Most other makers use a little grinding blade to finely chop the particles so they can be sent down the drain.)
Oct 04, 2010 | Bosch 24 in. SGS43C12 Classixx...
Water not heating up in my Bosch classixx dishwasher yet it still goes through its cycle ( but a lot slower )
your water temp is noot correct. the heater only really maintains the temp it does not raise the temp from cold to hot. if this is helpful send me a 4thumbs up post.
Feb 22, 2010 | Bosch 24 in. SGS43C12 Classixx...
Conditioner not emptying in Bosch Classixx 1200 Washing Machine
ITS NOT THE DRAW THATS NEEDED CLEANING ITS THE JETS ABOVE IN ROOF OF DISPENSER THESE ARE DIFFICULT TO CLEAN UNLESS YOU USE HOT SOAPY WATER AND A SYRINGE TO FORCE THE BACTERIAL GROWTH BACK DOWN THE PIPES,IF YOU DO THIS KEEP GOING TILL NO MORE BLACK STUFF COMES OUT THEN TRY IT IT SHOULD WORK LEAVE THE DRAWER AJAR WHEN NOT IN USE THIS WILL CUT DOWN THE MILDEW GROWTH.
Sep 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx 6 1200 washer
Problem will be ... machine will use your hot water during the rinse cycles! So, No.
Aug 14, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
206 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
