Question about Apex Digital Televison & Video
On just one of my channels I can get video, but no audio
    Top Expert:
  • Apex Digital Master
  • 74,482 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 01, 2014
Rca wire colours are
The most common colour convention is:
Yellow: Video
Red: Audio, right channel
White (or black): Audio, left channel
Green; Centre audio
Blue: Left Surround
Gray: Right Surround
Brown: left back surround
Tan: Right back surround
Purple: subwoofer
Sep 13, 2013 | Car Audio & Video
I can't get the speaker B option selected on my Sony STR DH800 7.1-Channel Audio Video Receiver
If you're using the terminals for Surround Back (7.1) there is no Speaker B option.
See the notes on page 19 of the manual.
Mar 03, 2010 | Sony STR-DH800 7.1-Channel Audio Video...
No audio
just check that the audio or this channel hasnt been set to zero and saved that way go to channel 4and select the volume up on the remote to ensure it is set to on
Jul 30, 2009 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
May 27, 2009 | Televison & Video
When I connect a DVD player, there is no audio or video.
Select "Video 1",or whichever input you have connected the player to. It is not available on "channel...accordianman
Nov 12, 2008 | Toshiba 27A33 27" TV
What tv channel do I use with Durabrand DVD Player model: DVD-1002 lvjack@juno.com
Some DVD players that has a built-in RF Modulator would normally use either Channel 3 or 4.
Most do not and uses Audio/Video OUT and therefore must not be on any channel but on VIDEO. Chances are you have to hooked up the DVD using Audio/Video with the RCA cables (yellow, red & white). The TV must be set to Video IN not TV Tuner/Channel. Additionally some TVs can only accept a mono audio input while your DVD's audio output is stereo. A quick and dirty way out is to use an adapter shown below to convert the stereo to mono. Additionally, some other TV's Audio/Video inputs are on the front panel.
Alternately, if the front panel Audio/Video connector is already being used by another device, an RF modulator may be used and this time your TV has to be switched to a channel prescribed by the RF modulator. A fine example is one from RadioShack.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 26, 2008 | Televison & Video
What channell do you tune to for dvd output for durabrand model Dwt 1905
I believe its not on a channel but on VIDEO. Chances are you have the DVD hooked up as Audio/Video using the RCA cables (yellow, red & white). The TV must be set to Video IN not TV Tuner/Channel. Additionally, your TV can only accept a mono audio input while your DVD's audio output is stereo. A quick and dirty way out is to use an adapter shown below to convert the stereo to mono. Additionally, to my knowledge your TV's Audio/Video inputs are on the front panel.
In some instances, there are DVD players that has a built-in RF Modulator and normally uses either Channel 3 or 4.
Apr 18, 2008 | Televison & Video
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Televison & Video Logo
27 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
