Question about Whirlpool duet Washing Machines
Have codes F7 and E2 on front panel. What is problem? Washer only 2 months old.
    Sergeant:
  • 197 Answers
F7 motor triac fault . best to contact your supplier, as its still under guarantee!
Posted on Nov 30, 2014
4 Suggested Answers
SOURCE: Whirlpool gold catalyst washer front panel and pump
two screws in the back of the unit on the corners of the control unit unscrew them and lift up and back on the control under the control there are two gold colored clips that have to be pried up from the front to release the cabinet from the base I had to take the whole tub apart the problem seems to be caused by over use of fabric softener the shaft from the holding tank that the agitator tank sits on gunks up with softener residue and acts like a brake and won't let the washer spin to get rid of the water it's not that hard to do just remember that when you put the cabinet back on that the front goes under the base and the sides sit on top of the base on two little points
Posted on Sep 01, 2008
  • 1028 Answers
SOURCE: whirlpool duet washer throwing H the F code
f06 usually means problem in motor speed circuit either main control or motor control or possible wiring connections..FH is usually a problem with the flow meter left side under top has small hose from fill valve and one to dispenser...it's not reading water flow to machine a light tap may help confirm problem if doesn't help may need to change flow meter anyway small switch on small bd with wires will stick and not signal main bd there is water flow
Posted on Oct 02, 2008
chrisd999
SOURCE: whirlpool washer f3 e2 code
Had the same F3E2 error on our Amana (made by Whirlpool) washer, and I found a broken black wire amongst the group of wires hanging from the bottom of the wash tub. It broke right at a tie-wrap. Must have been caused by all the movement. Anyway, joined the wire with a marrette and some electrical tape, and the fault cleared.
Posted on Mar 02, 2013
Whirlpool washer f3 e2 code
your main control board is having a problem need to have service rereplace it free of charge and the board has been upgraded
Sep 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How do I stop the error E2 code on my washer? I
The E2 shows that there is a motor problem. This can be caused by having an extra heavy load in the machine so take some out and try it. It can also be cause by any iof the buttons being stuck so make sure they are all 'free'. If this fails then you will need to have a new motor and call a repair man unless you can do the job yourself.
Sep 11, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washer does not spin or agitate at all. Timer works.
Check your belt. It may have become loose.
On the top right and left of the front panel insert a putty knife about 3 inches in where the top meets the front panel.
This will release the front panel so that you can see the motor and belt operation.
Better still, a 5 month old machine call for factory authorized service.
Feb 24, 2009 | General Electric WBSR3140GWW Top Load...
E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Nov 20, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
CANNOT RESET E2 ERROR CODE TRYED UNPLUGGING DID NOT WORK
I have only worked on USA machines but I believe you have a control panel error.
Sep 27, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool duet front loading washer
your inlet water valve is not closing and needs replacing, in mean time turn water off between washings.
Apr 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GH7208XR Error Code #7
Behind the right front corner faceplate is a bag with the tech support info.
I used this and went through all the troubleshooting and got to the power inverter board. This board has the 2 red wires out of it that go to the magnetron. Instead of replacing the whole inverter module , I examined all the components on it. I found that there are 2 high voltage rectifier diodes attached to the transformer and 1 of them was not testing good. The diodes are UXC2B diodes.. Just clipped out the bad one and soldered in a new one.
Hope this helps..
Dec 21, 2007 | Whirlpool GH7208XR Convection / Microwave...
Maytag Neptune Front Loader - E2 error code
The first time my E2 code came on the washer won't rinse or spin. I checked the drain pump to make sure it was working. (1) Take the back off and pull the two drain lines off pump. Be careful the line going to the drain has a backflow flap, make sure you don't tear it.
(2) On the other side where it drains from the washer to the pump is where I found a bobbie pin that had collected lint and was blocking the drain flow.
When it can't drain the E2 code comes on to let you know it won't rinse or spin.
Make sure to unplug machine before removing back,
Hope this helps everybody with E2 problems.
stude
40stude@bellsouth.net
Nov 29, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
150 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
