Question about Garden
How do I adjust the screws on carb on McCullough model 40005102 gas blower
  • 755 Answers
If equipped with screw limiters you can only adjust slightly using a flat or phillips screwdriver. If not limiter equipped you may need a special driver that only authorized shops are supposed to use. EPA is tightening stuff up on small engine carbs for some odd reason. You might want to try adding some fuel system cleaner and seeing if your blower picks up on the top end without any twiddling.
Be safe and good luck!
Posted on Dec 01, 2014
5 Suggested Answers
  • 149 Answers
SOURCE: poulan pro bvm200 leaf blower/vac won't run on high
Is the exhaust spark arresor screen clean? a blocked exhaust will do this.
Posted on Jan 08, 2009
sparksflyin
  • 47 Answers
SOURCE: homelite backpacker blower # uto08083 not running
fist thing is run both the carb screws all the way in then back them off 1 1/4 turn this will be your starting point then start the blower to fine tune the carb if it starts then your carb was off giving it to much or to less fuel
Posted on Feb 05, 2009
  • 124 Answers
SOURCE: How to adjust the carb on a McCulloch super
There is no set adjustment on any blower or chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the
adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Posted on Sep 20, 2009
daneinwv
  • 124 Answers
SOURCE: husky 125B blower, new right
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Posted on Dec 09, 2010
Echo blower isles but dies on acceleration
Assuming the gas filter and carb is working properly then you would need to adjust the high side idle screw on the carb. The newer carbs have a protected head on them and you need a special tool to adjust them. If you look at the adjusting screws on the carb you will see a "L" and "H" the screw next to the "H" is for the high side mixture. If you are not able to make the adjustment then the Echo dealer should be able to do it for you. Hope this helps.
Oct 01, 2016 | Echo Garden
Adjust choke
I am not sure about yours but my Craftsman has a adjusting screw in the carb to set the gas. If it is choking you screw it in a little and if it falters screw it out a little. You should be able to adjust with it running. Just turn a little at a time. Mine uses a flat screw driver.
Jan 22, 2014 | Garden
Illustated parts list for mcculloch leaf blower model 40005102
parts can be found at amazon, click here and take a look: Amazon com mcculloch leaf parts. I hope this was helpful.. have a nice day
Oct 04, 2011 | McCulloch 26cc Gas Blower Mcb3208
Need carb adtusted
Hold @ full throttle and adjust high (H) screw until she raps out to max RPM, let off, if idle is rough adjust low (L) screw until idle is achieved, You should have it, if not, clean carb and check fuel filter.
Nov 26, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Jun 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
I have an 28 cc McCullogh leaf blower which will
Check for spark in the new spark plug, if you have spark clean the carb fully and try again. make sure you have correct mix of gas to oil and it is not old use fresh gas oil mixture. Good luck pal.
Jan 23, 2010 | McCulloch 26cc Gas Blower Mcb3208
My gas trimmer settings for proper fuel, air mixture is messed up, do I tighten all the way up and back off two turns? can't seem to find the right settings. There's two screws, one left one right?...
The screw closest the carb is the low speed adjustment, the outer screw is the high speed adjustment. Start with both screws one turn out and go from there. Hope that helps. Dwain
Jun 29, 2009 | Garden
Homelite backpacker blower # uto08083 not running
Dec 20, 2008 | Homelite Consumer Products MightyLite...
PoulonPro Leaf Blower will not run properly
the carb has a screen in it it needs to be cleaned out the fuel gets crystalized in the carb when it sits for a while. and if the carb has a high and low on the carb meaning 2 screws on the side of the carb .one is for air and the other is for fuel try this first start it up and give it full throttle and turn the high adjustment till it does something screw it in slowley and or out till it is at full rpm sometimes the adjustment screws do vibrate there way out of adjustment .if it dont work then take the carb apart to clean out the screen
Nov 13, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
