Question about Sharp El-520x Advanced Scientific Calculator White Bp Package Of 5
How do i put my sharp EL-520x calculator to degrees
I pressed mode but there are number options.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Press SETUP 0 0
If you need a manual you may view/download it at Owners Manual User Guide for Sharp El 520x Advanced Scientific Calculator...
Posted on Nov 30, 2014
informatica
  • 1114 Answers
SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Posted on Aug 10, 2007
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Posted on Apr 20, 2008
  • 359 Answers
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
SOURCE: need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Posted on Mar 13, 2009
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
Does the Sharp EL -520X do the same as a Texas instruments ti-84
No, the EL-520X is a scientific calculator while the TI 84 Plus is a graphing calculator. It can display graphs which the Sharp cannot do.
Dec 01, 2015 | Texas Instruments Office Equipment &...
Convert decimal to fraction
If you have just calculated some value and it is displayed in decimal format, you may be able to recover the exact fraction by pressing the key (change) or the fraction key [a b/c] itself.
Sep 24, 2014 | Sharp El-520x Advanced Scientific...
Where is the EE key on a Sharp EL-520X?
It's just above the "7" key, marked "Exp".
May 09, 2014 | Sharp El-520x Advanced Scientific...
How do i change the view to view rationals in exact form?
Try pressing the key marked [a b/c] a few times. It toggles between improper fraction, mixed number, and decimal representation.
Apr 21, 2013 | Sharp El-520x Advanced Scientific...
Why can't I multiply negative numbers on my El-520x???
Make sure you use the +/- key (located just to the right of the decimal point key) to enter a negative number, not the - key (to the right of the + key, used to subtract one value from another).
For example, press +/- 4 / +/- 3 = to divide -4 by -3 .
Jan 19, 2013 | Sharp EL-520XBWH Scientific Calculator -...
How to work with complex number
Press 8 2ndF , 6 2ndF ->r(theta) and see r on the display.
Press 2ndF <-,-> and see theta on the display.
Press 2ndF <-.-> to switch between r and theta.
Dec 06, 2012 | Sharp EL-520X Advanced Scientific...
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
Sharp El-520x Advanced Scientific Calculator White Bp Package Of 5 Logo
1,244 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
