Question about Tablets & eReaders
Cannot turn on. Battery does not hold charge.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 17 Answers
I guess your battery is faulty. It may be a result of overcharging which may have caused the battery to be bloated. High voltage from the charger could also have been a reason for the battery's fault.
For this case, I believe your battery is in-built into your tablet. I suggest taking it a repair centre. Also, avoid charging or using as as it may lead to electrical circuit faults which may cause sparks within the tablet.
Posted on Nov 30, 2014
My Kindle Fire HD is frozen. It says that there is 96% battery. I don't know if I'm supposed to disconnect the battery (which I cannot access) or what. Help!
You can try holding down the power button to see if it gives a menu to turn off the device. If not, you can also try plugging in the power to see if that unfreezes the screen. If neither of those work, you can let the device run out of battery and then charge it again, as it will restart the system after losing the battery and gaining a charge again. After it runs out of battery and you have it charged again, you will need to hold the power button to turn it back on
Apr 13, 2017 | Amazon Kindle Fire HD
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
My nabi shows the red charging light but won't turn on please help!!
The charging light may come on but that does not mean the battery holds a charge....have the battery checked
Jul 16, 2015 | Tablets & eReaders
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
My tablet will not turn on after charging it all night. Can I change the battery?
press and hold the power button 10 sec ?
Press and hold both power and volume down buttons for 10 seconds, then release vol. down button while holding down power button for another 10 seconds, before releasing.
plug to pc and wait to be recognized?
take out the battery so that samsung fully discharge so this should help reset replug the battery.
Jan 04, 2015 | Supersonic 9.7" Android Tablet SC-97JB
Why wont the internal batteries hold a charge ?
You have a problem with the battery or charging line. If you have indication from Windows for charging battery, mtery.aybe you need a new bat
Sep 10, 2014 | Microsoft Surface 64GB Windows RT - with...
After purchasing this product, how long do you have to let it charge before you can turn it on to use it?
First lesson here in charging 101: read your info on what u got. In most of them it tells you to turn it on and use it until the item you got dies then you charge it, you can turn it on if u want to see it charging but don't play on it. An it's best to do when you can watch it, so charging it overnight is NOT good, because it will be done before you wake and over charging is not good. It makes the battery weak so holding a charge gets less and less over time. Never leave your cord in the wall when it's not charging your item. Power from the wall is still running through it and slowly frying it. Thats why people go thought many cords for one item. The reason for the first battery kill and then a full charge is a stronger battery life. It gives your battery about (but don't hold me to it) a 15% increase on life. So back to your question. It depends on the item and battery life it has when u pull it from the box. In most cases battery is about half full. Plus charging from a outlet lets say to a car charging is better and faster for your item. When most battery's are being made and tested in factory's it is a outlet that is being used. So most info on timing a charge is based on info gathered From tests done from a outlet
Sep 05, 2014 | Visual Land Prestige Pro 7D 7 inch Tablet...
Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Jun 27, 2012 | Micro Innovations Velocity T103 Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
