Question about Harman Kardon AVR 55 Receiver
Avr 55 wont power up
Amber light is on- no fuses blown- will not power up
    Habit-Forming:
  • 166 Answers
Units in protection due to fault check speakers
Posted on Dec 01, 2014
Cps1000 avr wont power on
The unit has an internal fuse that could be blown. Also the batteries dont last forever.
Apr 25, 2014 | APC Computers & Internet
Denon AVR-4806CI won't turn on.
you must check first the fuse in the power supply which getting blown.if the fuse blown with darkened black color that was mean there are other component parts in the power supply or in the board which get bad. if you know how to test component, check shorted bridge type diode as will as regulator ic and FET transistor in the power supply board.
Aug 16, 2012 | Denon AVR-4806 Receiver
Why can't I turn my canon printer on? I've checked and double checked that all connections are tight. I may be low in one ink cartridge but since I can't turn the machine on I can't...
If the printer is plugged into an AVR or a UPS try plugging it directly to a known good power outlet to make sure that it's not the UPS or AVR that's causing the trouble.
Another thing you can try is to make sure that the power cable is ok. Eventhough it's intact wires from inside the power cable might have melted so try swapping power cables or if you have a power tester check for the continuity of electricity on the power cable.
If both looks good and the printer still does not want to turn on, check if the power light has any sign of life, does it give a blinking amber light or no light from the printer comes out at all?
If there is a blinking light or a steady amber light try to remove all the printer components (inks, cartridges, etc. and put them back in then try turning the printer on)
If it still does not work please provide the model number of the printer as a service might be needed to make sure that the capacitors, IC's and the PC-board of the printer is ok.
P.S don't forget to check the fuses to make sure that they are in good condition.
Hope this helps!
Jul 10, 2011 | Office Equipment & Supplies
My daytime running lights wont come on
The Daytime Running Lamps module is bad or check underhood fuse block for blown fuse.
Are the daytime running lights on this vehicle the amber ones or white ones? Are they the headlamps or the driving lamps below?
Aug 11, 2010 | 2007 Cadillac STS V Sedan
Model W2607C. Does not power up.
Check the 27 mhz oscillator on the back of the main board. Resolder of replace it. It causes lots of different blinking amber lights.
Sep 04, 2009 | Dell W2607C Television
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
Harmon Kardon AVR-55 fuse schematics
F101 is 8 amp / 250 volt slow blow
F103 is 315 mA / 250 volt slow blow
Jan 11, 2009 | Harman Kardon AVR 55 Receiver
Denon AVR 3806 - No Power
open unit replace fuse....im sure u have blown fuse..
rate me fixed ok
Feb 14, 2008 | Denon AVR-3806 Receiver
Harman Kardon AVR 55 Receiver Logo
99 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
