Question about Coffee Makers & Espresso Machines
<!-- from fixya rte -->I put water in and nothing comes out - Coffee Makers & Espresso Machines
Follow the three steps:
1. Check if the coffee machine is connected to the power socket and is getting power.
2. Pour the water in the correct place in the machine.
3. Make sure you switch the machine on when you pour in the water.
All these places like the position of the power button and location to put the water will be marked in the User Manual. Please refer it.
If it still doesn't work you may want to call customer support as specified in the manual.
Posted on Nov 30, 2014
I have no cold water hose so I put the hot water one on but the water isn't coming out how can I fix it
all washing machines require both hot and cold water lines . better get a plumber to assist you
Sep 23, 2016 | Washing Machines
Astoria sae 2n . the lights stay on. They do not flash. Nothing comes out of the heads but water did come out of spouts that are located directly behind panels. There seems to be one for each espresso head...
Has the machine been cleaned / descaled? Coffee machines become clogged with mineral scale deposits from the water. Some folks use citric acid , about two tablespoons /qt of water, and some folks use white vinegar, 1/2 & 1/2. Place the solution in the machine as if you were making coffee. It may take a few cleanings if there is a lot of deposits. After cleaning dissolve two tbsp of baking soda in a quart of water and run through machine to neutralize the acid.
May 13, 2014 | Coffee Makers & Espresso Machines
Lavazza does not steam
put in steam nozzle something like a long needle or something similar.
Dec 07, 2013 | Lavazza Espresso Point Capsule Machine
No water from shower
Take the cartridge back out and turn it 180 degrees. Put the front toward the rear. It sounds like you got it in backwards. It's a very common mistake, even made by master plumbers.
Dec 03, 2012 | Home
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
Light on but nothing happens
Sound like the diodes stuffed FOR THE MAIN UNIT.
I'd be taking back to the supplier/ STORE
Apr 30, 2012 | DeLonghi BC0261 Espresso & Coffee Maker
I have two and both are having problems! The first one - when I put a whole pot of water in only a half pot comes out. If I put another whole pot of water in on top of that still only a half pot comes...
  • The sprayhead may be clogged. Check the round disk (sprayhead) above the brew funnel. The holes in this part must always remain open. If they are clogged, remove the sprayhead and clear the holes using a toothpick. Always unplug the brewer before deliming or cleaning the sprayhead.
  • The brewer could be clogged with mineral deposits. See the Deliming Instructions in the Manual. NOTE: The frequency of deliming depends on the mineral content of your water.
May 16, 2011 | Bunn VPR Coffee Maker
No water comes thru My Single-Cup Keurig Brewing System
Obviously a redtriction michael. They work like the old perculators . See if you can sccess and make sure the tubing is seated snd that the water is heating. Good Luck Michael
Oct 19, 2009 | Coffee Makers & Espresso Machines
Nothing going on
need to remove the lower panel below the door and unscrew the big white cap and clean out the pump pluged up this will fix the problem beware all the water in tub will run out on floor if hose coming from pump is not pinched closed
Nov 11, 2007 | Kenmore Elite 45986 Front Load Washer
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
