Question about Chamberlain Power Drive 3200, Ga420d Swing Gate Opener
Hi. I just want to find out. I just bought a second hand gemini motor. It seems to work and everything bit when the gate rail is on the motor the motor dont want to open or close anymore but when i push the gate it opens. It seems like the motor itself doesnt have enough power to open the gate. Its a normal gate. Not heavy or something. If someone can please tell me whats wrong and what i can do. Is a gemini dc motor. Not sure what model
5 Suggested Answers
blanchettohd
  • 143 Answers
SOURCE: the gate opener is elite
Thanks for using fixya.
The clicker manual does not list this as a device it is compatible with. I would not think it would as a regular security plus remote or 315 remotes do not. I would buy a passport remote. You can find these at chamberlain.com. Thanks BB
Posted on Sep 05, 2010
  • 59 Answers
SOURCE: i purchased a replacement garage /gate opener but
Hi, not sure what instructions you have, but the ones you can download are very clear here is a link Chamberlain Clicker Universal Remote Control KLIK1U
Posted on Apr 10, 2011
BangBang101
SOURCE: Hi I've got a Gemini gate motor installed, every second day the fuse (16Amp) on the main PC blows, what can be the problem
Replace it with a Centurion.
Posted on Apr 14, 2012
emissionwiz
  • 80339 Answers
SOURCE: Hi everyone. This would be a huge help if use can
The system is operated by hydraulic pressure the pump you hear is the hydraulic pump running, but your fluid has leaked out due to a problem in the lines or the cylinders that lift the top, you have to tear it apart and find the leaking parts.
Posted on Oct 15, 2012
What could be wrong? Our Gemini gate motor works well for some time, but then all of a sudden just go backwards when it should close the gate. It just revers with each attempt to let it go forward till at...
You could have dirty photo cells or some obstruction that the photocells are picking up that triggers the safety mechanism to reopen the gate so that no one gets hurt.
Extreme weather conditions (heat and cold) can damage the electronics in the photo cells too.
Are the batteries low on the transmitter?
Typically, photo cells are (or should be) wired to the control board so that it will stop the gate or barrier during the closing cycle should there be a problem- and should fully open again- just like on automatic garage door openers; it's the exact same principal.
Feb 28, 2015 | Cars & Trucks
Gemini gate motor
Check if it has stops anywhere in the system, usually there are micro switches that are activated by arms, etc that tell it how far to open and close. You may need to adjust them.
Aug 20, 2014 | Cars & Trucks
Hi i have just bought a brand new but second hand
Your brand new secondhand USX-800 may be no good. From your description it seems you have done everything possible to get it to work
Aug 07, 2013 | Audio Players & Recorders
My Centurion D5 will intermittently reopen the gate immediately after I close it. The LED lights flash 4 times which I believe indicates an obtruction but there is no obstruction. Any thoughts as to w
Hi there. The symptoms you describe as well as the error indication (4 flashes) certainly do seem to indicate an obstruction. Try disengaging the gate, moving it back and fourth and feeling whether it sticks at any particular point. Possible causes could be: dirt or stones on the rail, bad rack joints, missing teeth in the rack, worn wheels or guide-rollers or a damaged rail. You can also try decreasing the collision sensitivity (I can send you an email with the info if you like), but please be advised that this makes the gate less sensitive to an obstruction and could pose a risk. How old is the motor, if I may ask?
Nov 27, 2012 | Cars & Trucks
How to programme a nova 4 button remote on a gemini gate motor
It's important to know that the Nova remote controls are not compatible with the Gemini gate motor. In order to get these remote controls to work with your Gemini gate motor, you'll need to install a Centurion receiver first (see http://www.centsys.co.za/upload/product_link_files/CS37_Nova_Receiver_Instructions_1031.D.05.0012_4.pdf). Once the Centurion receiver has been installed on your Gemini gate motor, follow the programming instructions as per the leaflet that accompanied your brand new Nova remote control, or download the instructions from http://www.centsys.co.za/upload/product_link_files/English_Transmitter_InsertCS37_1031.D.02.0027_1_Nova.pdf
Feb 22, 2012 | Televison & Video
Basically i bought the nt1a second hand and plug it into my preamp and have no problems until i start recording and slowly the pickup of the mic fades away and i have to either make a loud noise to...
Seems you might have a gate inserted on that mics channel. Or if you are going to a computer, the program you are using might have an insert activated with a gate. Which means when signal gets to a certain threshold, the gate opens and the mic signal passes thru, below the threshold...the gate stays closed and the mic signal will not pass thru. Hope this is helpful.
Apr 12, 2010 | Rode NT1A Professional Microphone
TT 02 doesn't spin - Help!
i don't know if these are belt driven or not but i would check to see if the belt fell off, if motor driven then i would suspect a bad motor.
Dec 31, 2007 | Philips gemini TT-02 Turntable
Chamberlain Power Drive 3200, Ga420d Swing Gate Opener Logo
91 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
