Machine displays F:12. How do i correct this problem?
    Problem Solver:
  • 5 Answers
If you have the w/m booklet it will be in there by way of an explanation as to what the F:12 is if you can't put your hands on the booklet then. google the machine and fault code
Posted on Nov 30, 2014
The adjust temp numbers on my GE side by side fridge went out
Try this 1. First make sure the machine is turned on and running, both fans and compressor should be running. 2.Then unplug the machine for minimum 2 minutes. 3.Restore power to the refrigerator and wait 2 minutes. 4.Control diagnostics test using the display does not use error codes to identify problems. Instead, the temperature display allows access to components or systems to be checked if a problem is detected. 5.The temperature display must be in an active mode before entering the self-diagnosis test. 6.If the display is blank, press any temperature button once, then release it. The display will show actual temperatures.7. Enter the diagnostic mode by pressing both the freezer temperature (COLDER and WARMER) pads and the refrigerator temperature (COLDER and WARMER) pads simultaneously. All four pads must be held for approximately 3 seconds. Blinking "00"s in both the freezer and refrigerator sections of the display indicates the refrigerator has entered the test mode. 8.Remove fingers within 5 seconds and press any pad to lock-in the test mode. The blinking "00"s will change over to solid (non-blinking) "0"s when the test mode is locked in Failure to lock-in the test mode within 30 seconds will time out the test and return the refrigerator to the normal cooling mode. 9.Use the temperature colder or warmer pads to enter 1 in the freezer display and 5 in the fresh food display and press any button. This will cause a system reset.10. Wait 30 seconds and try to adjust the temperatures again. If the problem still exists, remove the cover over the motherboard behind the machine.11. Measure the voltage between J4-2 and J4-3 You should have 12 VDC (do not disconnect the J4 connector).12.If the voltage is correct confirm the voltage on the display board J3-2 and J3-3 I 13.if the voltage is correct, replace the display board. If not replace the motherboard.
Aug 24, 2017 | GE Refrigerators
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
May 01, 2011 | Canon FAX-B820 Plain Paper Bubblejet
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
May 01, 2011 | Canon FAX-B840 Plain Paper Bubblejet
Please can you tell me how to change time and date. thank you. Wendy
The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
Start/Enter. The display asks you to choose a date format.
3. Press Start/Enter.
4. Press left arrow or right arrow until you find the desired date format, then press
Start/Enter.
If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
The display shows the currently set time and date using the selected date format.
5. Enter the correct time and date using the number keypad.
Day = 01~31
Month = 01~12
Year = four digits
Hour = 00~23
Minute = 00~59
You can also use left arrow or right arrow to move the cursor under the digit you want
to correct, then enter a new number.
6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
The display shows the time and date you have set, then returns to
Standby mode.
06-25-1999 12:30 ('USA' type)
Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do i change the date and time on the devise?
Press MENU until "Machine Setup" appears on the top line of the display. Press the scroll button ( < or > ) to display "Date & Time" on the bottom line and press ENTER. Input the correct date & time using the number keypad. Month = 01 ~ 12, Day = 01 ~ 31, Year = requires all four digits, Hour = 01 ~ 12 or 00 ~ 23, Minute = 00 ~ 59, To select AM or PM in 12 hour mode, press * or #. Press ENTER when finished. Page 1.31 in user guide.
Dec 03, 2009 | Ricoh FAX2210L Plain Paper Laser
How do I set the time and date for the fax on my Xerox Phaser 3200MFP
From xerox.com support for Phaser 3200
NOTE: If the printer has been powered OFF for a long period of time, the date and time may need to be reset when the printer is powered back ON.
  1. Press the [Menu] button on the Control Panel until 'Machine Setup' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button on the Control Panel until 'Date and Time' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Refer to the table below to enter the current date and time using the numeric keypad.
    Unit
    Range
    Month
    01 - 12
    Day
    01 - 31
    Year
    four digits required
    Hour
    01 - 12 (12-hour mode)
    00-23 (24-hour mode)
    Minute
    00 - 59
    NOTE: By default, the clock mode is set to the 12-hour mode; however, the clock mode can be modified to the 24-hour mode. See the Related Items below for additional information.
    Press the [*] or [#] button on the numeric keypad to select 'AM' or 'PM' for the 12-hour mode.
    If a mistake is made, press the [Left] or [Right] arrow button to move the cursor under the digit to be modified, and then enter the correct digit using the numeric keypad.
  5. When the date and time are correct, press the [Enter] button.
  6. Press the [Stop / Clear] button on the Control Panel to return to the Standby mode.
Jul 29, 2009 | Xerox Phaser 3200MFPB Multifunction...
Xerox 6110 24h error
1. Press Menu until System Setup appears on the bottom line of the display and press OK.
2. Press OK when Machine Setup appears.
3. Press the Scroll buttons until Date & Time appears and press OK.
4. Enter the correct time and date using the number keypad.
Month = 01 to 12
Day = 01 to 31
Hour = 01 to 12 (12-hour mode)
00 to 23 (24-hour mode)
Minute = 00 to 59
Note : The date format may differ from country to country
Jul 09, 2009 | Xerox Phaser 6110 All-In-One Laser...
Wrong time printed on fax
  1. From the machine, press the [Menu] button until 'Machine Setup' appears on the top line of the display.
  2. Press the right arrow button until 'Date & Time' is displayed on the bottom line, then press [Enter].
    1. Enter the correct time and date using the numeric keypad. By default, the machine clock mode is set to 12-hour format; however, this can be changed to a 24-hour format (see the change the clock mode section below).
    2. Month = 01 ~ 12
      Day = 01 ~ 31
      Minute = 00 ~ 59
    Note: To select 'AM' or 'PM' for a 12-hour format, press the * or # button or any number button.
    1. Once the correct date and time has been entered, press [Enter].
    2. Press the [Stop / Clear] button to return the machine to Standby mode
    Feb 19, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
