Question about Coffee Makers & Espresso Machines
On the slide to insert the canister there is a half moon metal strip that hooks to the slide. One side has come loose. How do I get into the top piece to reconnect the metal slide to the black slide??
Tried to slip the piece back over the side snap with no luck
xedcom
  • 127 Answers
SOURCE: DS broken in half
I recommend you to change the broken case, you can choose to change only the hinge and keep the good case parts or change the entire shell. By the way stores usually sell the entire shell so you can choose. As your screens are still working you are lucky because so often the brown flexible conductor to the top screen get broken so be careful.
You can also use a silicon or hard plastic case to put over your broken NDSL to keep it in place just as the fast non technical option.
Here are some links and you can find text and video guides googling around.
Shells in ebay
Other stores items
Good Luck...
Posted on Nov 09, 2007
IFIXALL
  • 868 Answers
SOURCE: MAYTAG AGITATOR LOOSE
replace the agitator,if you look for a store that sells used machines you'll get the best price. Buy a used one!
Posted on May 26, 2008
SOURCE: ELECTROLUX model 1623 switch replace
Hi jjda..slide the strips/bumper...maybe it's hard to slide off...but try again...this week-end i open my 1623 too...no screws..just the strips hold the top and the base together..good luck!...Joel
Posted on Sep 29, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Metallic-like cardboard insert inside microwave is crumbling???
That piece is called the waveguide cover. Emerson calls it a spatter shield. Behind it is the hole where the microwaves enter the oven. Its job is to prevent food spatters from getting into the microwave source, and it's not a good idea to run the oven without it.
The cover is usually held in place by a plastic rivet that pulls out. I couldn't find the part number for the cover used in your model. But here is a link to a parts place that has several covers available:
http://www.a-1catalog.com/wavandstirco.html
If one of the covers shown looks like yours you can order it. Another possibility is to contact Emerson at 800-695-0098. This is the number they give to locate authorized servicers near you, and you might be able to order a replacement cover through them.
Hope this has helped. If so, please take a moment to rate the solution. Thanks for asking here!
Posted on Mar 03, 2009
  • 10 Answers
SOURCE: Weber Q 120--propane leak when removing canister
i would say that might be faulty mine just screws together and unscrews nothing falls out
Posted on May 01, 2010
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
I locked my keys in my 04 tahoe
ok this is what you do to get in without AAA or a locksmith. find a long piece of metal bendable wire. (metal coat hanger) and make it striaght and make a hook on the end of it. Next find a wedge (door wedge works). put the wedge in the side of the door. where the front door meets the rear door. and push it in to slightly open the door. Its easiest to insert to wedge at the top side corner near the top of the window and slide the wedge down to near the door handle to make the opening wider. next (with the wedge stuck in the door crack) slide the long metal wire into the opening at the top of the door corner and either press the unlock switch or grab the door handle and open the car. good luck! hope this helps ya
May 04, 2011 | Chevrolet Tahoe Cars & Trucks
I want to open the cannister to work on the cord rewinder but I don't want to force it and I am unable to locate/see how the back latches work.
This should really be done by an authorized Aerus Electrolux servich technician. I've seen quite a few dismantled machines come into the shop because the owner couldn't figure out how to put it back together properly. And the cordwinder can be even more difficult. The service techs really don't like to put together a dismantled machine.
There are no back latches.
However, to open the canister:
You will need a flathead screwdrive and a hammer.
1. Remove bag
2. Lay on one side, with bag door open all the way
3. Push tip of screwdriver in the back of side rubber strip.
4. Use hammer to hit screwdrive toward front of vacuum.
5. When strip is 5-6 inches out, grasp with fingers and and slide gently out the front of vacuum.
6. Repeat for other side.
7. Lay machine on it's top and lift bottom half of canister off top half.
8. You now have access to cordwinder. I suggest you take notes as you go so you remember where everything goes.
Putting it back together isn't this easy.
Nov 23, 2010 | Electrolux Lux 5500 Canister Vacuum
Tip
How to repair laptop key
If your keys fell off from your keyboard, you can easily repair it by following the installation guide below.
You should have a key cap, one large and one small plastic pieces (retainer clips).
Take the larger plastic piece, it must have two larger sticks at either sides that are going to click onto the larger metal hooks on the keyboard.
Take the small plastic piece. It must have a small bar on one side that is going to click onto the smaller single metal hook on the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece. Make it one piece.
Put the plastic piece into the metal holes on the keyboard. Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces so that it clicks together.
That's all.
Source: http://www.laptopkey.com
on Dec 01, 2009 | Computers & Internet
Can't open the bloody thing .... to check the power terminals connection
I strongly suggest not opening it. Although it is simple to open if one knows how, there can be difficulties getting it put back together correctly. And generally problems are due to things other then wiring connections.
However, to open, open bag door and remove bag. Place machine on one side with the door open. Insert flat head of a screwdrive into the space at back end of the rubber strip on side of machine. Using a hammer, gently hit the screwdriver shaft until strip slides forward about 4-6". Grab front end of strip and pull forward. Repeat with other side. Place vacuum on it's top, grasp bottom half of case, and lift. With some manipulation it should come off fairly easily.
Reassembling is a bit more difficult.
Be aware that shops will usually charge more to reassemble a vacuum if they didn't take it apart or repair it.
Oct 04, 2010 | Electrolux Lux 5500 Canister Vacuum
Can not put together
No official B&D diagram, but userLovenheim from http://www.fixya.com/ posted his/her own picture which I'm posting here: 8d59edb.jpg
Aug 05, 2009 | Black & Decker 5700 Powershot Forward...
Switch is not working I want to change it but I cannot access it.
THE LONG PLASTIC STRIPS DOWN THE SIDES HAS A TRACK IN IT. YOU MUST OPEN THE DOOR AND PULL (SLIDING) THE STRIPS OFF THE TRACK LONG WAYS AND THE TOP HALF WILL SEPERATE FROM THE BOTTOM HALF. BEWARE THE WIRING INSIDE IS JUST LONG ENOUGH AND CAN DISCONNECT EASY. IM PRETTY SURE YOU HAVE TO DO THIS TO GET TO THE BOARD INSIDE.
Mar 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
How do i open a electrolux ultralux 2000
If I am right, there is a strip down the middle, on each side, they slide off then, the 2 halfs will come apart.
Jan 15, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
