Won't turn on
Checked circuit breaker
  • 20 Answers
Some things to check, check the air handler drain line see if there is a float switch, to prevent floods. It may be bad or pan full of water due to clogged drain line. Open airhandler cover after turning off power breaker and see if small fuse on control board is blown.
Posted on Dec 02, 2014
  • 22 Answers
Please provide system type,make, and model number.
I was vacuuming turned off won' come back on
Well, Is it a canister vacuum or does it use bags?
Did it turn the circuit breaker off?
If so, reset circuit breaker and try to turn it back on.
Jun 01, 2017 | Vacuums
Light Switch Won't Work, How do i fix it?
Sounds like the switch its self is broken REPLACE IT make sure serciut breaker is off first
Jul 08, 2013 | Electrical Supplies
FURNACE WON'T TURN ON: I have a 1999 Fleetwood, Prowler RV. The furnace won't turn on.
Check the exhaust port of the furnace. Wasps like to build nests in there and it will not allow the furnace to ignite if blocked. You have a gas detector and it is turned on I assume? I forgot this many times.
Apr 20, 2013 | Heating & Cooling
It won't turn on
check the electrical outlet and, or, the circuit breaker to your washer
Feb 04, 2013 | Miele Novotronic Premier 500 Front Load...
Can i make a 40 amp circuit breaker with two 20 amp breakers?
Yes. A two-pole breaker is just two breakers hooked together. But the very important part is that if one pole trips THEY MUST BOTH TRIP. If only one trips, then the circuit won't operate the appliance (whatever it is) but one of the poles will still be live!
Jul 19, 2012 | RTO Pushmatic 40Amp 2-pole circuit breaker
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
My circuit breaker won't stay in the on position. when you try to flip it to the on position it automatically goes back to the off position
either the circuit breaker is faulty or there is a fault in the circuit, this is something that would need to be checked by a professional
Mar 12, 2012 | Electrical Supplies
I have two cardio zone treadmills which won't start. console lights but nothing happens. checked the two fuses for continuity, both good. what else can i check? s/n 35005624 and 35005616
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
Sep 13, 2011 | Cardiozone Exercise & Fitness
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
My Paloma tankless water heater stopped working after we had a block out, all the lights are working and doubled checked the electrical connector.... it just won't turn on as it should when I run the...
Try reseting it by unplugging it. Also is there any display lights on (troubles). If that dont work it might have fried the circuit board in the black out.
May 09, 2011 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
