Question about Eljer Home
How do I fix a crack in my eljer whirlpool tub?
  • 659 Answers
SOURCE: installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
Posted on Mar 23, 2009
  • 5 Answers
SOURCE: EMBLEM, ELJER TUB. DO I CEMENT THE NEW TUB INTO THE FLOOR? HOW MUCH CEMENT AND WHAT KIND?
The tub should just sit on the floor, and caulked around to seal out any water. If it as a fiberglass tub, you might want to put some grout under the bottom to help support it.
Posted on May 01, 2009
SOURCE: installing whirlpool tub
If it is a five foot tub, home depot usually carries them, if not any plumbing supply store will have them.
Posted on Jun 23, 2009
woobie dog
  • 1273 Answers
SOURCE: New tub chipped
Most tub manufacturers sell a repair kit specifically for their brands, and usually are the best solution for repairing chips and dings. I would attempt to get their kit if it is available first. Normally, they are provided free of charge for damage discovered after installation, and at reasonable cost for owner inflicted damage. If such a kit is not available, you may have to "wing it"
Here are three possibilities, and I have used two of these.
If your tub is enamel on iron/steel, and you have the chipped out piece, you can reattach it with matching enamel (appliance) touch up paint as the adhesive, and it works as the crack filler as well. Reinstall the chip, and sand smooth after drying with auto wet sand paper, beginning with 800 grit and take it progressively to 1500/2000 grit, until the gloss matches the surrounding surface. This makes an invisible repair.
If the chip is in acrylic, you can repair with a fibreglass repair kit available at one of the home hardware type stores. Again, it is better if you can re use the chipped out piece. If it is available, mix the repair parts of the kit together and butter it into the groove (after trial fitting the chip). Place the chip back into place, and cover with wax paper. Weight the chip to keep it in place until it dries, and wet sand as before. This makes a "close to invisible" repair.
A better repair to acrylic can be made if you can grind some matching surface acrylic (gel coat) to dust and mix the dust with the fibreglass repair resin before re-installing the chipped piece. This makes a closer surface match, leaving the resin surrounding the chipped piece less noticeable. All of the materials used for this type of repair are compatable
If the chipped piece is not available, you can harvest a small piece from an out of view section to make the dust/filler and apply as a paste, filling the chipped area flush and sand smooth as before. This takes the artist's eye to get exactly right, but it can be done. If you cannot get a harvested piece from your own tub, you may be able to get a piece from the store where you bought the tub. If they have a damaged/returned tub, they will usually "donate" a small piece to help you out. I have seen returned tubs be sold for salvage prices.
Just as reference for future use, it is a good idea to cut a plywood cover for the tub, or to line it with cardboard when remodeling to prevent having these type of repirs added to your list of things to do. I learned this a while back, the hard way.
Best wishes. Hope that this was of some use to you.
--W/D--
Posted on Sep 13, 2009
  • 1015 Answers
SOURCE: eljer whirlpool triangle tub on/off switch works until you try to turn it off then it will either come back on, or pulse on and off until the unit is unplugged.
I would start by replacing the switch and see if that takes care of you problem.
Posted on Feb 06, 2012
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
Eljer jetted tub on and off switch will not work
It may seem like a dumb answer but check the ground fault outlet or breaker. Then make sure there is enough water in the tub. It should be a few inches over the jets.
Mar 23, 2010 | Eljer Home
Installing whirlpool tub
Jun 22, 2009 | Eljer Home
Apr 29, 2009 | Home
Installation of our whirlpool tub
Mar 22, 2009 | Home
Jets not working
i have seen this in the past, a ground fault electrical outlet on the inside of a roman tub,if you have a 2 story house look for access panel on or by tub. otherwise you have to remove tile or other to access motor, you probably need a step too anyways
Mar 12, 2009 | Eljer San Antonio Acrylic Whirlpool -...
Home Logo
54 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
