Question about Kitchen Ranges
I have an arr3140ss American gas range. Just recently installed new burner and igniter.Roasted and baked all last week no problem todayI turned on the overn abd got up to 550 for pizza. put pizza in
Nothing so far. It's not the gas valve because the top burners are working fine. Range is propane
  • 56 Answers
Sometimes the pilot light goes out on this type of oven. This could be caused by a draft, or sudden jolt. Even if the top burner is working, the bottom won't go on until the pilot is lit. Check your manufacturers' instructions for locating and re-lighting the pilot.
Best of luck.
Posted on Nov 30, 2014
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Posted on Feb 19, 2008
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
  • 3 Answers
SOURCE: hotpoint 30" self cleaning gas range with sealed burners - no bake
It may be the ignitor, they can crack and you wouldn't even see. Good news is they are cheap ($5-20) and they are usually easy to replace. But before you replace it...
When set to bake, does the "oven cycle" light come on? If not, that means no power is being sent to the ignitor. Reason? There is a switch in the oven latch, to make sure a) latch must be closed for cleaning cycle and b) latch must be unlocked for baking. On mine, the switch button gets stuck, so even when the latch is unlocked, it thinks it is locked and will not allow the bake cycle to proceed. Cycling the latch a few times may free it, otherwise you'll need to replace the switch (not that hard but a bit of a pain to get to).
Posted on Nov 22, 2007
  • 67 Answers
SOURCE: Bosch HGS442UC Gas Oven won't light
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
The oven gas does not come on? Top and Broiler does. Oven igniter does glow
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not light but broiler works
More than likely the igniter for the bake manifold has become weak over time and now needs to be replaced. Each burner manifold in the oven has a separate igniter. That's why your broiler still works. Due to the frequency of use, the bake igniter wears out faster and may require replacement more often. The following link explains a little theory on how these igniters work and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have any questions, please let me know. I hope this helps you.
Jul 09, 2009 | Hotpoint RGB745 Gas Kitchen Range
Cgr3765adc, during bake mode upper burner does not ignite, gas smell. upper burner does ignite during broiler mode however. this problem seems to be in control module perhaps, not with igniter or burner...
In bake mode only the bottom burner will ignite. The gas smell could be caused by improper adjustment of the air intake on the bake (bottom) burner or something (foil) covering the holes in the oven cavity floor.
Jun 10, 2009 | Magic Chef CGR3725ADS Gas Kitchen Range
Oven takes longer than expected to light
You probably have a bad gas valve, part # WB21T10014, unless the new igniter is defective. If your broil works, you can prove this by temporarily hooking the broil igniter in the bake spot. Hope this helps!
Jan 01, 2009 | GE Profile JGSP48 Gas Kitchen Range
Maytag Gas Oven top burner does not turn on when in bake mode
That is the way it works. If you have an convection oven then they both work in bake mode but they alternate between the two.
Dec 17, 2008 | Maytag MGR5751AD Gas Kitchen Range
Jul 18, 2008 | Bosch HGS442UC Gas Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Hotpoint 30" self cleaning gas range with sealed burners - no bake
Nov 15, 2007 | Kitchen Ranges
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
