Question about DreamQuest 100% Free Spades Card Game for Windows
Why do I keep locking up or getting kicked off spades
Scan for problems. scan okay
    Problem Solver:
  • 8 Answers
What are you using it from? Facebook, an app? Need more information to properly answer =)
Posted on Nov 30, 2014
Hi I have an 07 1250 sa bandit. PROBLEM.. The electrical connection from the generator is getting hot and emitting smoke! I have tried a brand new regulator and stripped down and checked the starter motor...
Typically a connector that gets hot is because of a high resistance connection on the spade terminals in the connector themselves or a bad ground circuit. inspect the connector for corrosion and if all looks clean the connector can be disassembled and the female connector ends re crimped to make a tight connection on their male counterpart. To test for bad ground use a heavy jumper wire to attach battery negative to engine case as well as a second jumper wire from battery negative to the harness side of black/white wire that is attached to the original battery ground cable.
Feb 22, 2015 | Motorcycles
Hi Got a 2013 sgh honda 125 bike hooter just went
First check the fuse is okay. If it is okay, horns generally work by earthing when you press the button with the ignition on. Turn your ignition on, find the 2 wires that are connected to the horn and check if there is power to one. If there is, earth/ground the other connection and see if it works. If it does I would suspect the wiring. Alternatively, remove the horn, connect one of the electrical spade directly to the battery live and then earth/ground the other spade. If it doesn\'t sound then it is faulty and cheap to replace. Of course check all connections are clean and well connected.
Oct 02, 2014 | Motorcycles
What could be causing lock up to kick on & off while driving down the highway?
sounds like your lock up converter is kicking on and off. a shift kit could help. just take it to your transmission shop and be done with it.
May 10, 2014 | 1999 Dodge Ram
Sony stereo
Check speaker wiring on the back for shorts, if okay! the problem is in the audio output ic in the unit.
Apr 22, 2012 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
I have a Mazda rustler 2002, suddenly its dead when I try start it, it push starts fine, jumper cables are dead as well? is it the battery or starter motor? I cant find any wiring daigrams on the net, to...
if it starts by push start and runs then it's obviously a standard. Then it's not your wiring it's your battery. now if your battery drains down quickly, then your starter may have an internal ground . but sounds more like a f ..upped battery.sometimes you may put a battery on a charger, and it may show that it is charged, but in actual fact bateries calcifie over time, and are use less.
May 18, 2011 | 2002 Mazda B-Series
We keep getting kicked off, and low signals..
if there is any water body nearby remove it try turning the tower and the face of the router towards the laptop
Jun 01, 2010 | Belkin N Wireless Router wireless router
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
Dryer will not dry with full load, keeps kicking off
if your belt is slipping change the belt also check the felt and rollers make sure thay are turning freely the next step after that is change the motor thank you for useing fixya please rate me
Mar 18, 2009 | Whirlpool LGR7646E Dryer
Miele Revolution 600
This is a problem with the hose, and unfortunately it will require replacement of the entire assembly.
The SES-125 hoses produced in the general vicinity of late 2002 had a tendency to start building up static and kicking the motor off after a few years. The problem was rectified, and the more current hoses do not have this problem.
Head to your friendly neighborhood Miele dealer and get a new hose, and this problem will not occur again.
-R
Aug 27, 2008 | Miele Revolution 600 Bagged Canister...
I have a neon sxt
take to auto zone have them scan it or advance auto michigan they do this for free but souds like cheap electrical part iac or ideal air throttle sensor okay
Jun 21, 2008 | 2004 Dodge Neon
Video Game Consoles & Games Logo
47 people viewed this question
Top DreamQuest Video Game Consoles & Games Experts
James Wishart
Are you a DreamQuest Video Game Console and Game Expert? Answer questions, earn points and help others
