Question about Dryers
WED5600XW whirlpool dryers not starting - Dryers
  • Dryers Master
  • 744 Answers
Hello Moezz;
My name is Peter. I am a retired field service appliance technical.
Unplug the dryer prior to the start of any work!
There are three areas that you need to check.
1.) Door Switch.
Open the dryer front door. In the upper left is a small pin that sticks out. Push the pin. Do you hear a click? If not you have a bad door switch. You need to remove the top cover to access the door switch. Having accessed the switch, remove the two contact wires. With a multi-meter set to the lowest ohms, put one meter lead on each contact, while pressing the switch in, the meter should read '0' if it is good. If you do not have a meter, join the two wire leads together and start the dryer. If it starts you have a bad switch.
WED5600XW whirlpool dryers not starting - 25301680-yudzge0n2ugbkkaxty0c5tth-3-0.jpg
Part number W10411936 - $22.00
2.) Poor Air Flow
If you do not have good air flow the dryer will not start. On the back of your dryer is a hot air distribution manifold. It is held on with several screws. Remove these screws. Inspect the lower connection and check the blower wheel for obstructions.
3.) Thermal cut-off fuse.
On your burner funnel there is a fuse. You will need to remove the dryer front panel to access. You need to Ohm it out as described above.
4.) Motor Pulley Start Switch.
On the end of your motor is a pulley. There is a lever arm switch that contacts the belt when you start the dryer. Move the lever arm. Do you hear a click? if not your have a bad starter switch.
Posted on Dec 02, 2014
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
Quiet wash 1 doesn't drain
the pump could be siezed or blocked. burnt rubber smell from the drive belt. look under the machine and try to turn the pump pulley
Apr 17, 2014 | Whirlpool WED5600XW - 27", 7.4 Cu Ft, He...
My whirlpool dryer won't start. I have taken the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Whirlpool Dryers
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
WHIRLPOOL DRYER WON'T START
It may be as simple as a thermal fuse. Some Whirlpool dryers have power for the motor going through the theraml fuse.
Mar 08, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
