Question about Fujitsu LifeBook AH532 Notebook
When system is start key f2 and f12 not work
Direct to the hard and start windows I can not install new windows just option for boot is hard disk
    Top Expert:
  • Fujitsu Master
  • 22,766 Answers
It is tricky to get the timing right. Press F2 repatedly just before the boot screen.
Posted on Nov 30, 2014
What can I do to reboot new hard drive
So a new drive will of course, have nothing on it at all. Lets just say you are installing windows 7. With the windows 7 disk in the optic drive as the power is turned on - check for boot options at start up or hit your Del key to get in to the bios. Search bios for boot priorities - Set optical CD/DVD drive as primary (first boot) Make sure you can boot to the windows disk.. Once it sees the disk in the drive - follow the directions and the disk with start the install process. AFTER your windows os has loaded, you may need to find orphan drivers that did not load with the windows disk. You'll have to search Dell.com for proper drivers. Oh, huge - If the computer is running SATA 1 - Pentium 4 to first generation Core 2. You may need to hit your F4 key to add other drivers at the very beginning of the windows install.
The drivers most the time, show as a raid driver, but this is needed or your system will never install - The Hard drive will never be found.
Hope this helps.
Have a great night..
Dec 19, 2014 | Dell Recertified - GX620/2.8/2G/160G/W7P...
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
System won't boot up window XP
HI Joe. It's likely you have a virus. Or could be just a corrupted section of the hard drive. The F8 is what gets you to the black screen with the differnt boot options. F2 or Del button gets you in the the BIOS or start up instrutions for the PC. F 12 will get you boot device options. The F12 or F2 needs to be pressed before it ever gets to try starting windows. So when you first power on, immediately start tapping the F12 about once a second. This should bring up a menu of which items/ device, to start from. [If you get a stuck key message just clear it and continue tapping F12 or start over] I would suggest you use the windos CD and choose the CD device to boot from, then it will recognize the CD drive. You could follow the CD start up options to peform a repair of windows. If you do a repair, then you should also perform a virus scan immediately after. If after all that, you still have issues, then it's likely the hard drive itself is bad or going bad and you should look at replaceing it. Good luck.
Dec 05, 2012 | Dell Dimension 8200 PC Desktop
Operating system not found on my laptop wot does that mean?
Operating system not found simply means that the laptop cannot detect that there's an operating system installed on your laptop.
It's either the hard disk got disabled in BIOS or the installed windows is corrupted. You might need to check in BIOS if the hard disk is still detected. If it is, make sure that on the Boot options, hard disk is selected as the first boot option. If it is, then that means that the windows installed on your laptop is corrupted therefore you might need to install windows using the recovery discs of your laptop.
By the way, to go to BIOS start tapping on F10 once the laptop starts to boot up.
Let me remind you that by doing this it will erase everything on the hard disk.
Sep 12, 2011 | Compaq Presario 1692 Notebook
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
-G33k
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
Cannot install windows 7 on hp media center (m8307c) computer. Using OEM windows 7. Says windows cannot install on computer hardware. Using 1.5 tb wdc replacing 500 gb wdc. HP has given up.
Try installing windows by booting from cd, restart your computer and while its starting up press the del button (there's usually a prompt to do so on the bottom of the screen), you will be taken to a bios setup screen. In this setup you can not use the mouse so use the keyboard to navigate to the "Advanced Bios Features" option, go down to "First Boot Device" press Enter key then select CDROM, press F10 to save then exit and restart the computer with the Windows 7 disk inserted, after a bit it should prompt you to press any key to boot from disk so press any key and your windows installation should begin.
May 03, 2011 | Computers & Internet
Hai my name is laman my lenovo laptop just haveasmall problem it's displays only press {f2} for set up press f12 for boot device selection & can not execute so any one please solve this problem
Pressing F2 is the shortcut key to enter in cmos setup or bios settings where you can setup interrupt request and the direct memory access and also changing system date and time. While the F12 key is a shortcut key where you can select a boot device which are the hard disk drive if it's loaded with the operating system like windows xp or windows 7 etc., and if you are going to install or reformat your computer select the cd/dvd room drive to be the boot device. Supposedly the computer will load after the F2 or F12 appears on your screen if you have the functional operating system. But if your computer still restarting and always appearing on your screen the said F2 and F12 keys that means it is required to be reformat your computer. But before that you try to tapping F8 key while turning on your computer and select safe mode and press enter, after loading and still restarting that is the time to format your computer but you must back up your data or files that you saved on your computer. Call a computer technician or IT that know how to back up and can format your computer. Have a nice day.
Mar 14, 2011 | Lenovo Computers & Internet
My desktop pc cannot boot again, it keeps on showing disk read error.
if its showing disk read error then possibly there is some problem with your hard drive or RAM. there are more chances that you have to change your hard drive.
but you can try one thing just boot the computer using a bootable windows disk and try to full format the hard disk and then install the OS. it should help.
but if there are bad sectors in your hard disk then it seems that you have to change your HD.
Jan 06, 2011 | Dell Computers & Internet
How do I install Windows 7 etc on new Asus 5X DC
get the windows 7 cd, put it in the DVD drive, watch for boot options when the computer starts something like "press F9" for boot options. Its typically (F9-F10 or F12) select boot from CD Follow the prompts. If you cannot locate the boot options. Go into System Setup at boot and change the BIOS Boot order, To CD first then hard disk. Cheers
Aug 25, 2010 | ASUS Computers & Internet
Fujitsu LifeBook AH532 Notebook Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
