Question about Zeiss CARL Visucam PRO NM Fundus Camera
Central glare visucam pro nm?
Used lens gentle lens cleaning technique taught by zeiss tech.
Zeiss ikon auto focussing Lens is pushed in. How to get it to work?
You may be able to pull it gently out (at your own risk) until it re-engages with the helical.
Jun 27, 2017 | Zeiss Cameras
What CMOS-battery goes into the Zeiss Visucam lite (build 2006)?
The battery is soldered to the CPU. People from Zeiss Germany said that it needs to replace all the CPU. Now a days there is no longer spare parts for that instrument. I recommen you just change the day and time each time you turn it on
May 30, 2014 | Zeiss Science & Laboratory
Microscope will not focus on high power cloudy
Since there's only a very small amount of light reaching the lens system of microscopes when on high powers, A special technique (called >>>oil immersion
Not using this technique must be the cause of the problem you are experiencing.
eHow will guide you through the exact procedure of using the oil immersion technique: http://www.ehow.com/how_8431358_focus-high-power-objective-microscope.html
Good luck in exploring the micro world!
Jul 09, 2011 | Zeiss Microscope
WHEN DVD IN IT SAYS NO DISC
Optical lens problem. I assume ure not a pro in repairing it, so send it for repair to local tech. Before u do that, get a lens cleaning kit and clean your optical lens. Usually the optical lens cleaning kit comes with a cd and solution. Use it according to the instruction manual. If still the same, then send it to tech for repair.
Jan 18, 2010 | Durabrand DUR-1700 Portable DVD Player
Wont read discs
The unit needs to have the laser reader lens cleaned but DONT use regular rubbing alcohol. Get pure stuff....the rubbing type leaves a glare on glass and plastic lenses.
Also ,the chrome rails that the laser moves along need to be cleaned and lubed with liquid silicone. This method clears read problems most of the time.
Dec 24, 2009 | Microsoft Xbox 360 Pro System Console
I have a tasco 2x7x32mm which has fogged up, It is to have a lifetime warranty and am looking for information on getting it repaired?
Can you unscrew or detach the front lens? You should be able to do this.
Get some eyeglass Zeiss cleaning tissues from Wal Mart, and clean it, very gently. Brush it off first with a clean camel hair brush.
If it is fogged BETWEEN the lens then it must go back to Tasco.
This is a VERY small diameter telescope. The same size as a pair of 10x50mm binoculars. You would have a better view of the sky with the binoculars.
http://www.handgunrepairshop.com/tasco.htm Warranty service
Dec 13, 2009 | Tasco Novice 30050312 (350 x 50mm)...
My ps2 wont read the disk can you help me
Try cleaning the laser with a DRY q-tip in a circular motion. Just be gentle ;)
If that doesn't work then the laser needs to be replaced :(
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
I have the first digital rebel and as of lately my images are not as crisp as they used to be. Im having this issue even when I use a tripod...I also use auto focus and the images are not as...
when you take the lens off .. there is a mirror and the CCD array ... those can get dusty or if anyone smokes around the camera then that gets on these parts .. you can dust the mirror and CCD behind with a soft clean camel hair brush but a good cleaning should be done by a pro .. thats a "front surface mirror" .. that is, the mirror surface is not protected by glass the way mirrors normally are .. so it scratches very easy ... there are special techniques for cleaning that must be learned before attempting a deep cleaning .. the back side of the lens also may have a smoky coating that has to be cleaned .. again a pro is best but you can use a lens cleaning cloth and solution .. (dont spray the solution into the lens . only on the cloth .. with every thing clean your camera should be back to like new performance ..
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Zeiss CARL Visucam PRO NM Fundus Camera Logo
Top Zeiss Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
