Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
In cold mode, it operate ok but in heat mode no good. The temp outside is not to low, 28-30F
  • 25 Answers
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Posted on Dec 02, 2014
  • jeff5may32 Jan 05, 2015
    This is not quite accurate. In winter conditions, while heating the ductless unit will not blow overly warm air. If you get 20 degrees F of rise out of the indoor unit, this is good. The mini-split units don't act like a gas burner which cycles on and off, blasting hot air. They blow warm air and run for very long cycles. Generally speaking, with a heat pump an extremely long cycle is a good thing. When they stop and start up again, there is a time lag before they put out maximum heat.
ACTECH
  • 80 Answers
SOURCE: intertherm heat pump
FIRST YOUR OUTSIDE UNIT PROVIDES HEAT BY USING A REVERSING VALVE TO CHANGE THE REFRIGERANT FLOW.THERE IS NO HEAT STRIPS OUTSIDE SECOND YOUR EMERGENCY HEAT TURNS ON ELECTRIC ELEMENTS INSIDE YOUR AIRHANDLER UNIT.IT SOUNDS LIKE SOMEONE HAS WIRED YOUR UNIT WRONG OR HAS THE THERMOSTAT SET IMPROPERLY.WHEN THE HEAT PUMP CANNOT SATTISFY THE SETPOINT THE THERMOSTAT IS SUPPOSED TO TURN ON YOUR ELEC. HEAT UNTILL THE LOAD HAS BEEN REACHED AND THE HEAT PUMP CAN CONTINUE TO MAINTAIN IT.
Posted on Nov 29, 2007
rayname
  • 70 Answers
SOURCE: Goodman GMNT furnace goes into 'lock-out'.
check to see if your intake pipe or vent is clear this could cause a flame jump and make it look like a bad flame sensor let me know if this helps
Posted on Jan 08, 2009
  • 92 Answers
SOURCE: Carrier heat pump: aux heat does not seem to work
you have a heat pump which removes heat from outside air when it is too cold out below 30* the unit can no longer produce heat and electric strip heaters kick in
Posted on Feb 06, 2009
  • 148 Answers
SOURCE: UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
Posted on May 03, 2009
  • 10865 Answers
SOURCE: Cannot set a/c to operate automatically
Here is the sanyo link which will give you a manual once you enter the model number.
http://www.sanyohvac.com/docs.php
That being said, did you put new batteries in the remote? get back and let me know i want to help you.
Posted on May 23, 2009
Bought a soleus air conditioner portable on and it worked great for week when drained it it has leaked ever since and not working as well to cool and sometimes gets e3 on displat
E3 error message which apparently means my air conditioneris working so well that it has internal frost. It then stops cooling the airand waits for itself to defrost. So every 5 minutes or so it would stop workingeven if the air temp was above 80 degrees. Also check one of this:
E3 Fault room sensor(s) (open or closed circuit)Code
E3Error detail Remote control transmission error (transmitting error)
Inspected unit Remote control. Hope this will help you. Good Luck.
Jul 22, 2011 | Soleus Heating & Cooling
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
What do the symbols on the display mean and which one does the cooling operate better on . model number kyd-32a thanks
Now symbols:
4. Sun- Heat
Dec 31, 2010 | Heating & Cooling
Rent a house with a daikin brc1c51/61 with no instructions on how to work control panel for cooling/heating
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode.For further details, plz:
www.devicemanuals.com/guide/.../Daikin-manuals.html
Dec 30, 2010 | Heating & Cooling
What is cooling and dehumidification mode
When dehumidification operation is set by remote controller,the intake air temp.is detected and the setting temp.is automatically set according to intake air temp. expl. Intake temp.78.8 set point will be 77. When intake air temp.is 2deg.below the setting temp.the indoor fan operates at iow speed or stops.It is just a way to controlle humitity rater than just temp.Some systems reach setpoint before enough humitity is removed,making house feel stuffy,or damp.
Mar 07, 2010 | LG LSC183VMA Split System Air Conditioner
How to use the remote control to set the desired temp
Indoor temperature Operation mode Target temperature
Less than 200C HEATING
(FOR HEAT PUMP TYPE)
FAN 23C
20C~26C DRY 18C
Over 26C COOLING 23C
You will get good results by applying this meter
Jan 07, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
I am working on a coleman self-contained a/c which is low on charge. it is for my sisters mobile home, what should the pressures be. Any other ways to check charge? The model # is 7330D901. Thank you very...
If it uses R22, with a 70F to 75F indoor temp, and a 70F to 80F outdoor temp, I would think the suction pressure would be 65 to 70 PSI. Liquid line pressure might be 200 to 250 PSI. On a warmer day, they could be higher. Granted, those pressures are for the cooling mode. If it is a heat pump, the pressures will be higher in the heating mode.
Jul 07, 2009 | Coleman Heating & Cooling
Dacor dishwasher doesn't get dishes clean Model MDW24S
sagegril you have a good dishwasher and your problem is not new / you belong to a very large club .ans. is 120 deg at the tap iwon't get the job done . and any higher tempt is child abuse .. your d/w probley and a pot & pan setting . and hi tempt wash/ and rinse . set these to work . run the long cycle / this raised the water tempt in tank . always use fresh dergt. ( not liq ) and not what is on sale . and your dw will start working for you . m.m
Jan 09, 2009 | Dacor ED24 Built-in Dishwasher
Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
Jan 11, 2008 | Whirlpool GS460 Gas Kitchen Range
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
