Question about Samsung HP-S5053 Television
Samsung HP-S5053 is making a high pitch buzzing sound as soon as i turn the tv on and stops immediately when i turn tv off.
Everything else seems fine
  • dupa22 Dec 01, 2014
    Appriciate your help. Not sure what a firmware problem is. does this sound like a easy fix or should it be done by a pro?
    Top Expert:
  • Samsung Master
  • 74,377 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 01, 2014
Testimonial: "Didnt find anything about buzzing sound for samsung HP-S5053"
  • The Knight
    The Knight Dec 01, 2014
    I do see it here by the first post by the site I've pointed out. Says; might be a firmware problem. Check this post once more..
  • 30 Answers
SOURCE: Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
  • 304 Answers
SOURCE: hp-s5053 samsung plasma with snow on hd content
It appears that the Main bd is bad. Try using Component cables instead of the HDMI cables and see if there is a change. If there is a change to normal picture then try another HDMI cable. If the problem returns then replace the Main bd. There three Main bds for this basic model number. You will need the version# found on the right side of the set to order the correct bd.
Posted on Jul 16, 2009
roety
  • 585 Answers
SOURCE: hd tv makes a hjgh pitched sound whats wrong
Hi, the high pitched sound is coming from the coils or transformers on the power supply.
you can isolate the noise by removing the back and with the set on press gently with a plastic handle/item on each coil till you stop the noise. , you will probably have to replace the coil or the whole power supply, but sometimes you can tilt it over or secure it with silicone and it will stop rimging.
please click a thumbs up it this helps solve your problem
Eric
Posted on Aug 19, 2009
ginko
  • 19396 Answers
SOURCE: I have a Samsung S5053
Hi.
The TV must obviously be tested and repaired, as it is faulty.
The ticking sound and the beep make think to a faulty PSU or to a defective main controller board.
The PSU is indeed the first culprit, but the part must be tested jumping control lines with live power to test higher voltage. Unless burnt areas or blown components (eg capacitors bulged or leaking) can be spotted at a glance on PSU board, the part must be tested, test is complex and pose safety issue. For this reasons the unit must be tested by a technician.
Here all parts for this set.
Here PSU: PSPF501A01A SAMSUNG S5053
Posted on Aug 13, 2010
micromatikal
  • 2777 Answers
SOURCE: I have a samsung widescreen
Unfortunately it could be a number of things, in order of likelihood it would be the power board, power supply, main board, color wheel, or even a bulb that is buzzing. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
But regardless it is a serious problem inside the TV and will only continue to get worse. I would definitely get it looked at.
Thanks
Tim
Posted on Sep 30, 2010
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
I have a samsung Hp s5053 and My TV is making this clicking sound and turning on and off. How can I Fix this ?
Any time you have this issues the power supply needs to be replace. Look for the number on the board it should be the biggest board on the TV. Google it and it very simple to replace.
Thank you
Nov 01, 2010 | Samsung HP-S5053 Television
Service engine soon indicator on and a buzzing/whining noise.
i recommend that you take it into auto-zone or a car shop asap. from what you have described the ticking as, it sounds like a bottom knock. as for the whine i don't know.
May 14, 2010 | 2005 Nissan Xterra
Hd tv makes a hjgh pitched sound whats wrong
Eric
Aug 19, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Jul 14, 2009 | Samsung HP-S5053 Television
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
