Question about Motorola Radio Communications
How do i program my 10x radios to work with my talkabout distance radios
  • Official Brand Answer
  • 1,623 Answers
If the manual provided doesn't help. Contact Motorola Solutions. Get Support
Mark
Motorola Mobility Support
Posted on Dec 01, 2014
    Master:
  • Motorola Master
  • 517 Answers
I posted to your last request. The 10X uses dip switches and not the PTT to program. Here is the link again:
http://www.motorola.com/mdirect/manuals/DistanceDPS_User_Manual_E.PDF
  • 3,100 Answers
You may also find more information here Consumer Two way Radios Walkie Talkies
3 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Posted on Apr 12, 2009
eradiostore
  • 1654 Answers
SOURCE: how do you charge the talkabout distance dps radio?
When facing the front of the radio you will find the push-to-talk (PTT)/monitor buttosn on the left side, and on the right side you will find a rubber flat which opens up from the bottom, and under the flap you will find the 2.5mm and 3.5mm jack. The bottom jack is the charge jack. OR you can also use a drop-in style charge with this radio (note there are charge contacts on the bottom of the radio.) All of this is with the thought you you have the HNN9044 or HNN9056 rechargeable NiCD battery installed
If your radio only has alkaline batteries they cannot be recharged in the radio (even if a rechargeable kind). Alkaline would require an external charger specifically made for the alkaline batteries.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/DistanceDPS_User_Manual_E.pdf
Posted on Sep 18, 2012
I can program my distance radios by holding button then turning on.but that dose not work on the 10x
Correct. The 10X by Motorola uses Dip Switches for both frequency and tone codes. Both are under the battery tray. As you look at it, the left switch which has 4 dip switches is the frequency. On the right is the tone board with 8 switches. You can match the Motorola Distance radios if you have the settings. The 10X has a lot fewer frequencies and tones to choose from. Try this link:
Nov 30, 2014 | Radio Communications
Is there any replacement for the rubber outer housing on my Motorola T6510 radios?
Replacement parts were never made available for the TalkAbout radios (other than the higher wattage TalkAbout Distance and Distance DPS). Your options are replace the radios, or watch for used radios for parts on ebay and other similar websites.
Best regards.
Jul 20, 2014 | Motorola T6510 XLR Talkabout Two-Way...
Need battery tray for motorola sport 10 x
Unfortunately, the battery trays for this Sport 10X radio, Sport 7X and the later model TalkAbout Distance DPS are no longer available. In our repair facility we often get requests for these battery trays, and as a dealer we have not been able to get them for several years. Your best option is finding a used parts radio somewhere like ebay. In some instances the original tray can be fixed if you still have it.
Best regards.
Feb 20, 2014 | Motorola Talkabout Distance DPS (10...
Motorola Sport7 modelP14SHC03F2AA
Here is a link to the TalkAbout Distance manual
The Sport 7 and Sport 10X were predecessors to the TalkAbout Distance. Most of the manual will be relevant to your radio. We will stay on the lookout for the Sport 7 manual and if found repost a solution here.
One primary different between the Sport 7 and the others mentioned is that it does not have a frequency eliminator code (PL, Private Line, etc.) It simply operates open squelch. If using this radio with other newer TalkAbout radios you would need to turn your Code to off (zero) on the newer units.
Best regards.
Jan 15, 2014 | Motorola Radio Communications
How do I find a replacement back panel for my Motorola 5700 talk about. Need 2.
Parts for the small size TalkAbout line of radios were never offered to dealers, other than batteries, chargers and accessories. Your best option is to purchase a used radio from ebay to scalp for parts, or possibly by contacting a vendor such as www.wirelesspro.com, who deals in lots of the smaller TalkAbout radios. They may have some which have been scrapped for parts.
The larger TalkAbout line of radios, such as the TalkAbout Distance and Distance DPS are repairable radios, and many parts for them are still available.
Best regards.
Sep 20, 2012 | Motorola Talkabout T5700 AA (22 Channels)...
I have an older model Motorola sport 10X radio that has two pin connection. I tried several of the Motorola two pin accessories but the pins are too far apart. Are there any adapters available?
You might try contacting the people at http://www.wirelesspro.com/. They seem to have a variety of accessories for the Motorola Spirit and TalkAbout line of radios. The Sport 10X was a predecessor to the TalkAbout Distance DPS.
Otherwise, you might check with your local Radio Shack. It is possible they might have a 1-pin device which might work with the Sport 10X. On some audio devices the second pin is only for stability. The main thing which would make a difference is size, length and placement of rings.
Best regards.
Jan 04, 2011 | Motorola 2 Pin Adapter 2-Way Radio
I need to know the watt of the t5509
The TalkAbout radios are 1/2 watt radios, with exception of the older larger TalkAbout Distance and Distance DPS, which were 1-2 watts.
Best regards.
Apr 12, 2010 | Motorola Talkabout T5500 (7 Channels)...
Need an owner / operator manual for a motorola sport SS radio. does anyone know where i can find / download one?
The Sport SS, is very similar to the Sport 7X, Sport 10X and the TalkAbout Distance radios. We were unable to locate the exact manual for the SS model. Here is a link to the TalkAbout Distance radio which may help: http://pdf.textfiles.com/manuals/SCANNERS-F-R/Motorola_Distance%20UHF%20Porto_Manual.pdf
Aug 22, 2009 | Motorola Radio Communications
MOTOROLA TALKABOUT T5400
First check your batteries. Try the battery pack from a known good radio. If you do not have a battery problem, your issue is probably non-reversible. Sorry. This style radio is non-repairable. The repairable Talkabout units include the Distance, Distance DPS, the TA-7400 and TA-7200.
Jul 11, 2008 | Motorola Talkabout T5400 (14 Channels)...
Radio Communications Logo
83 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
