Question about Plumbing
How do I get the lever back on my single lever Baypointe bathroom faucet? There is no set screw.
Inserting the lever upon the rod it swivels upon. You can turn the lever but it does not tighten.
    Master:
  • 560 Answers
Get the instructions from the manufacturer.
Posted on Dec 26, 2014
frcs68
  • 1605 Answers
SOURCE: single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Posted on Apr 22, 2009
SOURCE: need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Posted on Jun 18, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
  • 129 Answers
SOURCE: My moen single lever faucet is loose, how do I
On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
Posted on Nov 08, 2009
1stBSP
  • 52 Answers
SOURCE: I have a Moen Single Handle kitchen faucet, it's
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Posted on Apr 06, 2010
Bathtub faucet leaking a lot
Change the gaskets.
Popular Grohe 3427 Concetto... Repair Questions - Fixya
www.fixya.com/support/p1162411-grohe_3427_concetto.../popular
Popular Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair ...
Grohe 3427 Concetto Single Hole Bathroom Faucet ... - Fixya
www.fixya.com/search/...grohe_3427_concetto.../grohe_faucet_leaks
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome, grohe faucet leaks related issues. Get free help, solutions & advice from top Grohe experts
Nov 04, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
The sink stopper came off on my talia bathroom faucet and I can't get it back on
UNDER THE SINK ABOVE THE TRAP IS A TAILPICE WITH A ROD POINTING TOWARD THE BACK WALL. IT IS HELD IN PLACE WITH A NUT. REMOVE THE NUT. PULL THE ROD OUT. TURN THE POPUP LOOP TOWARDS THE BACK WALL SO YOU CAN PUT THE ROD THROUGH IT.SNUG THE NUT UP AND CK TO BE SURE IT WORKS. FILL SINK WITH WATER AND CK FOR LEAKS.
Apr 18, 2014 | Grohe Talia Widespread Bathroom Faucet...
Flip over bathroom plug in bath stuck & bath full :/
follow this steps and fix it. God bless you
  1. Remove the shower head from the pipe.
  2. Clean the arm threads and wrap them with plumbers' joint tape.
  3. Screw the head back on and hand-tighten it. Remove any excess compound or tape.
  4. Test and retighten as needed.
Repair a shower head that leaks at the swivel:
  1. Unscrew the shower-head body from the swivel-ball ring.
  2. Find the O-ring or a similar seal inside. Replace it and screw the shower head back into place.
  3. Turn off the water supply and open the faucet handle to relieve water pressure.
  4. Carefully loosen the coupling nuts at the shutoff valves and at the base of the faucet.
  5. Carefully remove the supply tubes.
  6. Remove the locknuts that hold the faucet to the sink and lift the faucet out.
  7. Clean the area where the old faucet sat.
  8. As needed, install the new spray hose and supply tubes, if any, through their holes in the sink.
  9. Set the rubber gasket that came with the faucet on the sink where it will be mounted. If no gasket is supplied, apply plumber's putty.
  10. Set the faucet into position and center it.
  11. From under the sink, attach the faucet locknuts to hold it to the sink.
  12. Reinstall the supply lines, then turn them on and test the faucet. Turn it on carefully because the line and faucet have air in them.
Nov 28, 2013 | Home
I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
I have an american standard bathroom faucet. Single handle. It is leaking where the faucet meets the sink. I do not see any screws to take off the handle. How do I fix it?
First, turn off the water supply under the sink. Next, put the faucet lever in the up position, no water should be coming out. While in the up position turn slowly while looking at the underside of the handle and you should be able to find a set screw. It will probable be an "allen head" type and you will need and allen head wrench to loosen it. An allen head looks like a hex shape, 6 sided I believe and is rod shaped. If you don't have one they come in sets at your local hardeware.
Jul 16, 2010 | American Standard - Lavatory Faucet -...
Need technical diagram of single hole faucet
Not sure where to find the diagram, but what type of faucet is it and where is it leaking? It it's a single lever, remove the hot/cold indicator to uncover an allen set screw. Loosen it and remove the lever, then the outer bushing nut. Now you'll have access to the interior parts around the cartridge (make sure you turn the water off to the supply lines before proceeding further). If it's the two handle type, remove the index buttons from the top of each handle to uncover a screw with either a slotted or phillips head. Remove the screws and remove the handles. You now have access to the valves and seats. If it's a 12-year-old faucet, the o-rings and seats will probably need to be replaced and this will fix your problem. If it's a single lever type, you'll need to replace the seats and springs and it will probably solve the problem.
Jun 14, 2009 | Grohe 40367000 Chrome Accessories Single...
Plumbing Logo
59 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
