Question about Dryers
How do i get the belt around the motor pully wheel on a white knite cl637wv
I have got the belt round the drum. How do i get it around the pulley wheel of the motor, it does not seem big enough, do i have to pull it and stretch it to fit.
  • Michael Worthy
    Michael Worthy Nov 30, 2014
    Thanks for the help.
  • Michael Worthy
    In the end i put some butter down one side of the screwdriver [BELT SIDE] and slid the belt down onto the pulley wheel. Now working like new, and it is 34 years old, hope it lasts me till the end, it's a great dryer.
  • 1,583 Answers
If you can't push the tensioner pulley back far enough to allow the belt to go around it, disconnect the tensioner spring, route the belt, then reconnect the spring. If it's a question of having adequate strength to push against the spring and still have a hand free to route the belt, find something to jam against the tensioner to hold a bit of slack in the pulley. Make sure the jamming tool (large screwdriver, block of wood, etc.) is sturdy enough to hold securely, and well-braced. An ill-timed slip could cause severe hand injury.
If your dryer does not have a belt tensioner mechanism, the motor bracket probably has belt adjustment slots in it. In that case, loosen (but do not remove) the motor mounting bolts that go through the slots, push the motor over a bit to give you the slack you need,route the belt, then pull the motor back to tighten the belt and retighten the motor bolts. Sometimes a tight belt can be rolled onto the pulley by starting it on one side of the pulley and turning the pulley by hand while pushing the belt along in the direction of the turn, but it is better to mount the belt with slack in it; excess stretching causes premature failure.
Posted on Nov 30, 2014
mikedurland
  • 481 Answers
SOURCE: Fitting new drum belt to Simpson Dryer
it all depends on the brand of the dryer. go here for diagrams for a bunch of brands.
http://www.repairclinic.com/0079.asp
Posted on Jul 06, 2008
AlmostBob
  • 550 Answers
SOURCE: BELT WON'T TURN THE DRUM
there is a tensioner pulley as well as the drum and motor
It hooks into a slot, usually on the floor of the case, and has a spring that pulls it against the belt to tension the belt.
Broken belts have been known to knock the tensioner out of place, it should be sitting on the floor of the case as should its spring.
There is usually ony one slot for it to sit in, self evident if you know to look for it
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
fd5c779.jpg tensioner may be on the bottom run pushing up, or on the top run pulling down
Posted on Aug 28, 2008
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
  • 1122 Answers
SOURCE: Clothes Dryer belt assembly
yes,make sure you have the ribbed side on the drum-mike
Posted on Nov 04, 2008
SOURCE: I'm having a problem re-fitting the drive belt to
After some mild swearing, I made sure that I had the belt around the drum aligned (in the same plane) as closely as I could with the drive pulley and tensioning wheel. I think this was partially achieved by placing the belt as close to that position as possible before lining up the front end of the drum with the cabinet opening, and then turning the drum from the front (through the open door) very slowly clockwise (the direction of its normal rotation) to give the belt "time" to align itself fully with the smaller pulleys. A short prayer and a few minutes later, the machine was humming away with all parts playing their "part" in beautiful harmony - without the dreaded sound of a thin black drive belt cluncking to the floor of the metal cabinet.
Cheers,
Andy B.
Posted on May 02, 2009
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
How do you connect the belt to the pully, and drum?
loop the new belt around the drum,then take loop of belt under the idler pulley wheel and pull back on wheel to get slack to put remaining loop onto motor pulley shaft,then slowly release and idler will tighten up the belt automatically
Jan 02, 2011 | Roper REX4634KQ Electric Dryer
How to put a belt on a Maytag DE 410 dryer
with some you have to remove the front upper and bottom panel
then lift drum off bogie wheels and move it ahead a few inches then loop it over the drum and around the belt tensioner pulley most swing up and down so thatyou can put belt on
Dec 18, 2009 | Dryers
Drum not turning
pull the loop down at the bootm of the drum feed that loop through and under the pully wheel then catch the loop on the motor pully you can lift the idler pully slightly to get more slack
Oct 18, 2009 | Estate TGDS740JQ Gas Dryer
How to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Putting a belt on a whirlpool belt
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 15, 2009 | Whirlpool LER4634PQ Electric Dryer
How does the belt go on around the pulleys?
the idler arm has a white wheel. the belt sits on the wheel (both sides). Push down on the the wheel / arm and the belt should now go around the motor pulley. groove side of the belt is against the drum. So it should look like this, if your looking at it from back right side of unit, left side of belt against white wheel, press down and fit the loop around the motor pulley. Good luck!
Mar 09, 2009 | GE DBLR333EE Electric Dryer
Hotpoint aquarius drive belt wont go on
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Belt
Jan 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dryers Logo
57 people viewed this question
Top Dryers Experts
