Question about Konka KDL32AT23U 32 in. LCD Television
Iaccidendally push factory default on my remote now tv will not power on
UNPLUGGED IT AND TRIEDTO SEE IF THAT WOULD WORK ONCED PLUG BACK IN.Dis this a few times but still got no place
    Top Expert:
  • Konka Master
  • 74,383 Answers
Do a reset to this TV and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 01, 2014
Fire stick remote not working
Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. Press the Menu + Left (directional key) + Back buttons at once for 10 seconds. These are the steps for factory resetting of remote.
Apr 22, 2017 | Televison & Video
I HAVE 52" RCA TELEVISION.MY GRANDSONS WERE WATCHING IT USING REMOTE CONTROL.THEY DID SOMETHING;WHICH HAS CAUSED THE SCREEN TO SHRINK.PICTURE NOW HAS APPROX. 4" TO 6" ON ALL...
Can you please give us the exact model of this TV set so we can help you better..by the way did you try resetting the settings of your TV using the remote I believe there's an option there to reset the settings of the TV set....
Oct 21, 2008 | RCA Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
I have no remote and I think the TV is on child lock, it is a technika tv LCD 40" the stand-by light comes on but you can not get the tv to start. Is there a way to "factory reset" this tv without using a...
not sure it this will work on ur tv but try to unplug the tv, and push the power button on the TV and hold for 30 or more seconds,, on some TV's this little trick resets back to Default.
Jan 26, 2015 | Televison & Video
Tv powers off
Power cycle the TV: turn it off, unplug it and leave unplugged for about a minute. Plug it back in, turn it on and restore settings back to factory defaults. If this doesn't work, I would recommend pursuing repair/replacement options.
Nov 06, 2013 | Dynex Televison & Video
My screen is reading ' input is blocked ' we have no remote and now we can't watch anything. what can I do?
Have you tried to power cycle your TV? If not, try to do so and see if that works. Power cycling the TV can be done by turning it off, unplugging it, and then plugging it back in after a minute or so and powering it back on. Then restore settings back to factory defaults.
Nov 05, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
My t.v is stuck on the channel selector and nothing will move it. the tv turns off and on but that is all it will do.
Have you tried to reset the remote? To do so, press all the buttons at once & hold for a few seconds. You can then re-program your remote to the TV. Also, you can try to power cycle the TV by unplugging it, leaving it unplugged for a few minutes, and plugging it back in & restoring settings back to factory defaults. This should resolve the issue.
Oct 15, 2013 | Dynex DX-L32-10A 32" LCD HDTV
Volume control suddenly only adjusts to barely audible
Try pressing all the buttons on the remote simultaneously-this will reset the remote & then program the remote to the TV. You can also try and power cycle the TV by unplugging the TV from the wall for a minute, then plugging it back in & power it on. Restore any changed system settings to factory defaults.
Sep 25, 2013 | Dynex DX-LCD32-09 LCD TV
Samsung 46" DLP TV no picture or sound
Replace the TV, the cost to repair is about what new costs.
May 18, 2017 | Samsung DLP HL-P5663W 56" TV
PX- rc1
Basically all it takes to restore the TV to factory setting is to unplug the TV from power and all connecting cables for about 3-5 hours (depending upon your model). This is called a Hard Reset and should restore the TV back to factory defaults.
Oct 23, 2008 | Televison & Video
Konka KDL32AT23U 32 in. LCD Television Logo
93 people viewed this question
Top Konka Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
