Question about Philips SA3025/37 Flash MP3 Player
How to on it
To open it and see its internal parts
    Problem Solver:
  • 9 Answers
They are held together with internal clips which are hooked together like the top of two figure 2 locked together.
Posted on Nov 30, 2014
How do I get a phone number to call for parts???
Find a dealer in your local phone book that services safes. They are the only ones who can buy parts.
Jun 06, 2014 | Safe International Electronic Digital...
How to open internal wd 1600 hard drive case
If you open the case you will destroy the internal parts of the hard drive
Aug 02, 2013 | Western Digital Caviar WD1600 (1600YD) 160...
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Start button clicks but nothing happens after that
Pull down the starter it has internal problem, means no power is going to the starter motor. The possible culprit are the motor carbon brush that might be worn already and solenoid metal contactor that is worn or dirty.
Open the starter to check the internal part and replace parts that might malfunctioning.
Hope that helps you.
Aug 07, 2011 | Harley Davidson Bullet G5 Deluxe EFI...
It not turn on.
If u could open the internal part and check the THERMOSTAT and the THERMAL.
That usually the problem w/ FLAT iRONS!
Might as well check ur power cord too, it might have some internal cut wires in it, use ur multi tester to test the current continuty!
If u don't know how to OPEN it, u might as well, bring that to the nearest service center!
Nov 08, 2010 | Panasonic NIA56NR NI-A56NR Iron
Internal leak which is coming out from area above the swing out door (right side). Can I get a diagram of component parts which indicates how to open the machine to get at the internal parts? If I can...
I'm having an internal leak in a Vienna Digital as well (not sure where).
Found the following site has exploded parts diagram (although the parts are described in Italian). They also sell parts for the machine.
http://partsguru.com/SaecoViennaDigital.html
Good luck,
-- Glenn
Apr 04, 2009 | Saeco Vienna Digital Coffee Maker,...
My Inspiron 1100 won't accept the 1GB memory upgrade and I read somewhere that you have to remove the internal memory first in order to max out the memory. Do you know how to locate/remove this internal...
internal memory is located inside your laptop. u need 2 open it from behind. but it is very risky for you to open it yourself you might damage some parts on your laptop.
Jan 31, 2009 | Dell Inspiron 1100 Notebook
FREEZER OK / FRIDGE SIDE NO INTERNAL LIGHT & NOISE
your refrig has a bad electronic control heres the part #W10135090 the noise your hearing is an internal relay on the board buzzing trying to turn the lights on. i found the part at sears.com and it was ony about 80 bucks it is a plug and play part so you should be able to replace it yourself. the board is located in the white box next to the compressor in the back of your refrig. thanks peyton
Jan 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Philips SA3025/37 Flash MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
