Question about Canon PIXMA MX310 All-In-One Printer
I have a mx310 and where it feeds the printing paper do not print the printing paper goes to the side and it stops
I tried reset it and it did not do anything I also tried to see if jagged or if there was something in the roller nothing could u help me
  • Canon Master
  • 5,631 Answers
Looks feeder is broken. Even having the repair kit probably you don't have the technical knowledge to dismount your printer and change the broken piece so you should take it to an authorized Cannon repair shop
Posted on Nov 30, 2014
SOURCE: Paper does not feed - GRABS RIGHT SIDE
I once had a similar problem a few months ago and I tried EVERYTHING I could do (Without shaking the printer, I was scared to do that) nothing worked, till I actually got up on a chair and looked into my printer (It is up on a rise above my computer) and there was a push pin sitting in the feeder opening! (Remove pushpin = then it was fine)
Then it started doing it AGAIN yesterday at a time when I really needed my printer, and this time there was no obvious pushpin or any obvious obstruction. I read all the stories here and thought *WOW they had things that far in there?!" So I tried harder and FINALLY after opening the back panel I saw with a flashlight there was a FROOTLOOP (I don't even HAVE any frootloops in my dorm! XD) jammed in the right side inside it! With a chopstick I was able to get it out and now it's fine again. OMG.
But yea, things like to get stuck in printers I guess. XD
Posted on Apr 02, 2008
SOURCE: Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Posted on May 11, 2008
yooperbud
  • 8637 Answers
SOURCE: canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 11 Answers
SOURCE: paper wont feed propaly
It sounds like the motor on the left side went out. If it's a brand new printer your best bet would probably be exchange it at the store or see if the manufaturer has a warrenty. If it's an older printer I probably wouldn't try to get it repaired, printers are getting cheaper these days and it probably wouldn't be much more to get a new one.
Posted on May 26, 2009
APremkumar
  • 564 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
When I print, the paper gets jammed. The paper is grabbed on one side and goes in unevenly thus causing the jam.
Hello!
We must feed curved paper to our printer. To avoid paper jam let the paper be straight and dry... thanks
Sep 07, 2011 | Canon PIXMA MX310 All-In-One Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
My Canon MX310 printer is not printing. The paper feeder is not feeding the paper into the printer. It is feeding only on one side. We are unable to print or get faxes. Can you help me out?
It seems like there are some problem with roller inside..
If you have an air gun, try to get ride of dust as much as u can.
Or if you do not have one, ple use vaccuum cleaner...(at min. power) to **** out dust.
And then try for it.
Apr 08, 2011 | Canon PIXMA MX310 All-In-One Printer
When I try to print it starts a sheet of paper then lets go of it before it prints then says paper jammed when it has failed to load a piece. I have a pixma mx310
Clean the pick-up mechanism and feed wheels with isopropil alcohol and a Q tip. These items are probably slick and not gripping the paper.
Jan 24, 2011 | Canon PIXMA MX310 All-In-One Printer
Wont feed paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Feb 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Paper feed from rear tray pulls unevenly so paper gets snagged every time.
Jan 20, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Rogue jam
When on printer print test page always
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Canon PIXMA MX310 All-In-One Printer Logo
88 people viewed this question
old marine
old marine
